BFHOON
Everything posted by BFHOON
  1. I know how you feel jake, its like foot down........waiting for the kick in the pants followed by wheelspin but its like........nothing. I lasted 3000km stock before I wanted more.
  2. its amazing how much crap builds up under the rear mats.
  3. you will see. its where the hot side pipe runs under the fan shroud. you can put it on without cutting but it rubs so about 1 inch of a semi circle will do the job.
  4. hey mr r spec. have a look at this, clip on racing harness, a must for the weekend track warrior. you just replace the rear seat mount bolts with these hooks and that's it.
  5. its the same kit. try removing it all and get the stock pipe (the rubber one) and lay the rubber pipe out on the ground assembled as it came off the car. put the new hot pipes over the old stock pipe and make sure it all matches. that's what I did and it went on in about 40 mins. dont forget to cut a bit off the fan shroud so it dosnt squash the silicone elbow.
  6. tell him about the nos. you know u want to.
  7. if your ever in sydney your more than welcome to come give me a hand.
  8. naa the workhorse of the xr line and the best selling model will be deleted with the fg. of course there will be a fg ute, turbo, xr8 boss persuit and all the other variants.
  9. I had a shower in sodium hydroxide today, free chemical peel. the pump that pumps caustic into my water treatment plant had a hickup today so I removed the vertical output hose, removed the imput hose and connected it to the hot water to remove any dry caustic crystals, the result was hot caustic showering me from the outlet all over my face hands arms and neck. I went to the COLD emergency shower and rinsed down but it was too late. now im a nice shade of pink all over. the doctor says its not too bad and I got to it in time to prevent 3rd degree chem burns. I had a good day too.
  10. hi five.
  11. BFHOON
    3k To Spend
    a mal wood option 3 would be a good choice for a clutch. around 1800 with all the trimmings.
  12. it would be funny in redfurn. the guy rocks up and says wheres your wheely bin. the tennant says I cant tell you that the guy says come on mate wheres your wheelie bin the tennant says well mate iv wheelie bin in jail but dont tell any one aye.
  13. you can pay at the pump at any quix mobil store. thankyou and please come again(indian accent)
  14. BFHOON
    3k To Spend
    considering your budget I would reccomend a rapid systems cooler kit and a custom tune incorperating a capa flash tuner.
  15. I would have gone back to the car, checked the oil water cleaned the screen tossed some rubbish used a handful of paper towels and then left without getting fuel.
  16. BFHOON
    Overboost
    to add more. I can now, with a high flowed cat and plaz 800 kit , run 14 psi with no spike or fall off but if I add more boost it spikes and falls away to 14 again. I now need to mod my wgate and actuator to get a solid 15 psi.
  17. BFHOON
    Overboost
    on my car I had a plazmaman stage 1 kit with the stock zorst, it ran 211.5 rwkw on the factory tune and having 4.8 psi. cv dyno. this kit has the underbattery pipe and all the xover removed and replaced with big pipes. as soon as I started modding the exhaust I found that on the stock tune it would hit 8 psi and cut out. running my custom tune it hit 18 psi spike. up from 14. after zorst mods.
  18. coopers yaa, is good for me to be stayink over tonight yaa.
  19. you can do what you are asking to do but I would reccomend doing it on a dyno with all the correct meters and monitoring equiptment hooked up. at higher boost levels its easy to blow the motor. best not to go past the tuners set point as far as boost goes. if you are confident that the afr`s and timing are ok then a little more boost may help but if you dont know what your doing it could end up in a costly disaster.
  20. mine was doing the intermittent wrx noise and it turned out to be a misfitted rubber stopper on the number one spark plug. under the rocker cover garnish theres a set of rubbers that hold down the coil pack onto the spark plug.
  21. theres a bloke with a green car that may have a motorised pushbike for sale scribr.
  22. having a bad day mate?
  23. lol
  24. dont forget rapid now has an oem replacement cooler kit that uses most of your stock pipework and is cheap.
  25. its normal mate. they all do it.
