Deano82
About Deano82
  • Birthday 22/12/1982
    Victoria
  1. Happy Birthday Deano82!
  2. Ive only had the car for about 4 months so I would have to assume the battery is as at least a couple of years old. Th car is at the ford dealership now so hopefully they can sort it out without to many dramas.
  3. Angus & Cruze, did you fix this problem guys? What was the outcome? Its just happened to my car and the suspense is killing me!!
  4. Was driving my 2011 G6ET with trailer out of town couple of days ago and then randomly after 2+ hours driving (at night) the tail lights went out so pulled over turned it off and found the blown fuse and replaced to found the lights where back on so all seems fine so I went to start the car again to find the it wont turn over at all then faults had started coming up as - comms fault/airbag/seat belt and or pre tensioner faults. Anyone had this happen or know of something similar if so what was the cause/solution. Cheers
  5. Was driving my 2011 G6ET with trailer out of town couple of days ago and then randomly after 2+ hours driving (at night) the tail lights went out so pulled over turned it off and found the blown fuse and replaced to found the lights where back on so all seems fine so I went to start the car again to find the it wont turn over at all then faults had started coming up as - comms fault/airbag/seat belt and or pre tensioner faults. Anyone had this happen or know of something similar if so what was the cause/solution. Cheers
  6. Was driving my 2011 G6ET with trailer out of town couple of days ago and then randomly after 2+ hours driving (at night) the tail lights went out so pulled over turned it off and found the blown fuse and replaced to found the lights where back on so all seems fine so I went to start the car again to find the it wont turn over at all then faults had started coming up as - comms fault/airbag/seat belt and or pre tensioner faults. Anyone had this happen or know of something similar if so what was the cause/solution. Cheers.
  7. Was driving my 2011 G6ET with trailer out of town couple of days ago and then randomly after 2+ hours driving (at night) the tail lights went out so pulled over turned it off and found the blown fuse and replaced to found the lights where back on so all seems fine so I went to start the car again to find the it wont turn over at all then faults had started coming up as - comms fault/airbag/seat belt and or pre tensioner faults. Anyone had this happen or know of something similar if so what was the cause/solution. Cheers.
