Terribletory
1 Neutral
  1. Hey guys I pulled the earls lines and filter off gave them all the hell clean refitted them . First few minutes were the same then she come good thank god for that. Mind you that's only a small prob compared to other issues I've had with this car.
  2. Yes I did mate I'm dyslexic and cannot turn off simple functions in tapatalk
  3. Any ideas guys
  4. Hey guys my Territory turbo oil pressure light keeps coming on at low rpm. It was doing this a couple months back so I fitted an earls aftermarket turbo oil feed . The prob went away for about a month. But now has returned. Could it be a faulty sender or dying oilpump? Any ideas guys
  5. Yeah mate it was one of the fuel lines on the New Walbro 460 had come off. I was so relieved to see that. Now got to find good tuner and I'll be happy. Sent from my iPad using Tapatalk
  6. Mate tried the diesel thing . Your the man , never run so well. Thanks man Sent from my iPad using Tapatalk
  7. Yeah mate that's what I thought to. I'm on the Gold Coast if anyone can recommend a good tuner Sent from my iPad using Tapatalk
  8. So at the moment they have basically de tuned until I fix problem 340hp atw Sent from my iPad using Tapatalk
  9. The tuner set to 15 but was over boosting to 20 Sent from my iPad using Tapatalk
  10. Hi guy just had unsuccessful tune due to 4 inch dump into 3.5 system . Gtx 3582 turbo with all supporting mods. But no wastegate flapper mod . So had that done but now they tell me I need external waste gate. Is this right or should the internal flapper and porting mod be enough? Sent from my iPad using Tapatalk
  11. Thanks mate I'll try that now Sent from my iPad using Tapatalk
  12. Can someone tell me what will happen if you don't upgrade the relay when you install the Walbro 460 to the Territory Sent from my iPad using Tapatalk
  13. I drove for about 5 mins to get home then in the morning car ran on the spot but real rough , not drive able , so I emptied and filled with 98. Will start and idle for few seconds then dies . I have Walbro 460, 725 Bosch injectors, Turbosmart Fuel reg and rail adaptor. Fuel pressure originally was set at 58.5 no vac but now is under 20 Sent from my iPad using Tapatalk
  14. Hi guys have recently had territory turbo tuned to 98 then stupidly without checking tried E85. Car wouldn't run properly next day. Now I have drained fuel, car will start but has no throttle and will only run for few seconds. Is this a type of limp mode ? please any advice would be appreciated Sent from my iPad using Tapatalk
