keplaffintech
  1. I'm considering getting anti-lag launch control added via PCMTEC to my auto FG turbo. Currently making 280rwkw but might chase more in future. Will the anti-lag cause stress that is likely to break the stock oil pump gear set?
  2. All of the bolts seem to be present, and are in pretty tight. I can't see any that are missing.
  3. Just wanted to bump this as I haven't been able to find any leaks on the exhaust manifold, all the bolts are present and tight as. I have localised the leak sound coming from the back of the cold side(?) of the turbo. I did this using a microphone and headphones to track down the source. I have noticed an area where black soot is building up in this area. Could this be the issue? I'm not familiar with the actual housing components here, and it doesn't make sense why this would be on the cold side if it sounds like an exhaust leak. Pics here: Please have a look and let me know if that looks suspect.
  4. The manifold looks ok: However there seems to be a gap between the dump and cat here? Does this look normal to you? I did get the cat swapped out by a local exhaust shop. I'll probably take it to an exhaust shop once this lockdown is over, unless it's a matter of tightening that bolt
  5. https://youtu.be/clMCrHq64bQ Hi, I have an MkII XR6 Turbo with injectors, tune, and PWR intercooler. All fine for the last month or so until today when my car has started making a loud noise from the intake / turbo. I'm pretty sure it happened after a WOT pull, but don't know if that's just co-incidence. The noise is depicted in the video. It starts off pretty loud, but gets a little quieter when the car warms up. It is inaudible when off throttle, but can be heard at any point when accelerating, and is louder as you accelerate harder. I've noticed my car is notably down on power (timed a 6s 0-100 with this issue, used to be sub 5s prior). The wet stuff is soap water, as I was trying to identify any boost leaks, but couldn't. It sounds like it's coming from the turbo area, and as you see, when I move down to the cooler piping, or the right side of the car, the noise isn't nearly as prominent. Thanks.
  6. Has anyone fixed this problem themselves? Is it a dash out job? I have this problem (FG) and don't have warranty to cover it :(
  7. FG MkII Turbo Sedan - Just got rear swapped out for straight pipe. Sounds great, not too loud, but it drones at around 2500RPM (where the TC stalls of course). I presume adding a resonator will help? Do I need to get a specific type/size to match the RPM that the drone happens or will any do? Will it reduce the exhaust noise at 2500RPM? (it's a bit obnoxious driving in quiet streets at night)
  8. Making 13 PSI now, still gets there after a second or two of giving it a bootful. Was tuned by Joe from CMS - I trust that he's done as good as can be with the fuel and setup. Might look at getting a 2nd tune on 98 some day, then I can switch back and forth when necessary.
  9. Haha good question. Mainly I was curious as to how well it stacks up to 98. Seems I missed out on around 30kw when compared to 98 but I'm happy with that. I drive my car a lot and am only on max boost once in a rare while. I think I get what you're saying, the boost seems to come on in stages. e.g. no boost -> stock boost -> extra boost. Certainly less linear than stock. So that's just how it goes I guess?
  10. Just got my MkII FG turbo tuned to 280rwkw on E10 fuel. It feels so much stronger throughout the rev range, but, only once boost comes on. I know that off-boost it won't feel any different, but it almost feels like boost takes longer to come on now. Like a whole 1-2 seconds before it hits max boost, starting at say 3000rpm. Is normal for the stock turbo? Is there anyway to improve this?
  11. FG MkII XR6 Turbo (ZF) I plan to remove the 1st gear torque limiter to be able to stall above 2000rpm and build boost off the line. I also plan to tune to no greater than 300rwkw. Obviously the limiter was put in place for a reason, so I wonder what driveline components are likely to fail from building boost off the line? What should I consider upgrading? How does the stock ZF handle this at that power level? I don't intend to drag the car. As for why? I tried this in 2nd gear and it put the biggest smile on my face. That's reason enough 😄 Thanks
  12. Yeah, I don't know where everyone finds these reasonably priced labour shops 😞
  13. Exhaust shop tells me that swapping out the cat is either a $300 or a $1000 job depending on where the cat is. 'If the cat is up the top they have to replace the dump and cat'. Any one have some info on this? Thanks
  14. Yes, this will seem like a stupid question but bear with me: I run E10 in my FG MkII XR6 Turbo. It's 94 octane and consistently 24c cheaper than 98. Way better than running 91 on these turbo motors. I want to get injectors and a tune. Not interested in intake, cat, etc. Will 94 octane fuel really be the restricting factor at this point? Plenty of cars out there run high boost on 95 octane e.g. Audis/AMGs. The Fiesta ST can run on 91 and pushes out 18psi of boost no problem. Has anyone tuned on E10 or 95 and can advise?
  15. Hi, I have an FG mkii turbo that I'm looking to tune and get a bit of more note out of. Does a hi-flow cat + dump pipe (and a tune) have any noticeable impact on idle / wot sound? Assuming everything from cat back is stock. I have heard conflicting information here. Can anyone with experience chime in?
