El Andrew
Gold Donating Members
    59
  1. Ta. I should try and find an old pic and see if it was broken before the workshop fitted the oil line. There's enough there that I can probably cable tie the lines to what's left of the bracket.
  2. That sucks. I've pretty much decided for the Falcon that it only goes to a workshop if absolutely necessary. Too many stuff arounds, mistakes, broken bits. Weirdly I was just looking at that very bolt an hour ago myself as it has always annoyed me that the water line hangs a bit low. Is that plastic bracket meant to hold the water line and is the bracket in this pic complete or broken off? Edit: Puff's setup with the water line tucked above the bolt looks good. My filter in the oil line sits way to close to the belt.
  3. One simple job... Replaced my BOV. Went for a drive, no boost at all. Forgot the clamp on the throttle body. Tightened that and went for another drive. Plenty of boost, but also plenty of hektic dose bro. Turns out I had fitted the BOV the wrong way round.
  4. Haha could do that. Don't like my chances though. I yelled from the roof for the eldest to turn off the tap that feeds the a/c. He tells back that he is busy with Lego...
  5. Strange one. Drain valve is wide open, so the float valve is always open. If I manually tip the float, the water shuts off fine. If I turn the aircon on, the drain valve shuts properly and doesn't leak. But if the unit manually does a drain and refill after being off for a bit (to refresh the water) the drain valve stays open. Tech time I think - suspicious it is a control board issue. At least I cleaned it, checked the pad condition and cleaned the gutters while I was up there.
  6. Nice view though
  7. Morning all! Up on the roof for me this morning - evaporative cooler dumping water continuously when it is off. Hoping to find something obvious and simple like a blockage or float valve adjustment. But it stops flowing and works fine when the unit is powered on, so I'm thinking something in the control electronics is stuffed.
  8. Haha was an awesome story!
  9. Lol I'd have to talk him out of the beach camping trip first. Anyway, when the roads get twisty and I get enthusiastic he is worse than a Megane driver on a Snowys cruise...
  10. Would have loved to join you guys on this but unfortunately the dates don't work. Little tacker's 5th birthday that weekend.
  11. Enjoy! I friggin love the Foos and have since day one. Not going this time, partly because I now live in a city where they are never going to come so need time for travel. Saw them in Adelaide a few years back. 35,000 people and I was about 10m from the front.
  12. Thanks! Main problem was that there was a noggin between where my cables went in behind the monitor and out below the desk. Cut out a chunk of plasterboard, drilled through the timber, dropped the cables in, patched it up. Then it turns out one end of my HDMI cable was toast. Might test first next time... Yeah Home Mini. Came free with my phone. Mainly just use it as a speaker, but has got me using Google Assistant on my phone more.
  13. Slapped together a desk and chucked a monitor on the wall this week. While looking after the kids. Wife is away and should be impressed when she gets back.
  14. 4 year old from the back seat: "Dad, after this traffic light can you activate the turbo speed?" Moments after the light goes green, in a voice like he was relaxing into a hot bath: "Ahhhhhhh.... That's better"
  15. Wow my blood pressure went up just watching that. I would have made sure he saw me photograph his plates, photograph his face and then stood by his wife while I called the cops. *window not wife haha But yeah, she needs to make some choices about where her life is heading too!
  16. Thunder v Renegades at Manuka
  17. Great work Gaz - thanks!
  18. Probably having a look at a mate's Kia SUV tonight that has a clunking after taking foot off brake when stopped. Just had front brake pads replaced and noise started immediately after. Place that did the job had a look but sounded a bit useless and the problem remains. I was planning to have a look at the bolts holding the caliper brackets to the suspension, checking and greasing the slide pins and maybe lubing where the pads slide. All with the proper brake products of course. Might also check pads are firmly in place and can't slip around. Could be loose wheel nuts too, but you'd hope not if the place had the car twice. Any other immediate thoughts on cause? I'm going to assume it's not drivetrain or suspension related at first, given the issue arose after pad replacement.
  19. Hey
  20. Lol Rab. Dashcam in now too, with wiring nicely hidden. Feels good to do some upgrade job to the car rather than just fixing and maintenance.
  21. Nice! They cook cool but also pretty comfy. Unfortunately in my house if the dining furniture can't be hosed down its not worth buying!
  22. Interesting stuff. Was a nice surprise to get a few neat features in the AEM, given I only switched brands to reduce the risk of future headaches. I'll post up if I have any future issues. This one uses the 4.9 sensor too. Got to hand it to Amazon though - refunded the Innovate no questions asked, even return postage. Their scripted sympathy was amusing though: "Dear Andrew. I certainly understand how it feels when your Innovate Motorsports MTX-L Wideband AFR gauge stops working properly." Do you understand? Really?
  23. They do. Some people think that due to the way the Innovate controls the heating it kills sensors but I find that hard to believe, especially in such a short timeframe. But my sensor died so I played it safe and tried a different one!
  24. Wideband installation Mk 2. Those of you on the Snowys cruise will remember my wideband chucked a sensor error after about 30 mins of decent driving. A much easier job when you already have all of the wiring , relays and firewall holes in place! I switched from Innovate to AEM given discussions here previously about the Innovates eating sensors. Maybe there is something in that, maybe not but my sensor died so I thought I'd try something else. Good feelings about the AEM so far. Is shallower so was easier to find a decent spot for it, plus the wiring is simpler. Still has output to connect to other devices eg HP dongle. Apparently has a resistor to adjust calibration as it ages and so doesn't require regular free air calibration (although you can do this). Biggest win is that you can switch between AFR, Lamda and % plus other settings from the gauge - doesn't need a serial cable plugged into a laptop like the Innovate. Main downside is it looks a bit Skyline spec for my liking.
  25. Haha - we did agree on most things, which the tiler said was rare. The mirror over the bath is staying - it's the front of a storage cabinet recessed into the wall. Mirror should bounce some of the light from the window into the room. But yeah a tv there would be sweet!
