57
Something like that! They were a bit smoky. Rears are gone anyway and front on their way. Might go the PMUs, or even the SP500s Matt and Jet were recommending.
I’m about to get moving on a few things with my car and so thought it would be worth starting a thread. Calling this a build thread is probably a bit ambitious – more just my own history of what maintenance and upgrades I’ve performed and why. It is good to document this for myself, and hopefully it is of interest or use to someone along the way. Must be a few people who want better than stock, but not looking for a 600kW monster. My job is mainly human resources, so anything I tackle is a bit limited. The car is a BA XR6 Turbo in Lightning Strike (or ‘primer’ for short’). I bought the car in 2015 from a bloke in Sydney (I’m in Canberra) after a bit of searching – I was basically looking for something stock that had hopefully had a relatively easy life. The car had been a country car for most of its life and had about 125,000km. I really knew nothing about turbo cars at that point. So far in terms of basic repairs and maintenance I’ve done myself: -New NGK coils and plugs (this brand have been fine on stock boost, but will probably go genuine next time) -New high pressure power steering line – twice. First one was a Repco one that only lasted two years. Second one is a redesigned one from Ultimate Power Steering that allows the o-ring to be changed without replacing the whole line. -Full set of radiator and heater hoses -Front pads and rotors -Sway bar bushes, various front end bushes -Spigot gear in the rear driver’s side door lock actuator -All the usual stuff – coolant changes, brake fluid flushes, engine oil and filter every 5k. Trying to look after it and make it last. -Probably a few other things that caused plenty of swearing at the time but I can no longer remember Had a few other fixes that I've had done professionally: -New turbo!! Blocked oil feed killed the first one. Good news – housings were OK. Bad news – I’d bought an Earl’s filter and braided oil feed line a week earlier and hadn’t fitted it yet. Got a genuine Garett CHRA. A couple of mechanics have since said to me that it has some sort of upgraded core (ceramic bearings??) that have been available the last couple of years. Haven’t yet grabbed any part numbers and checked it out further. -A few bushes here and there (centre diff bush, outer upper rear control arm bushes) -Tailshaft centre bearing The stuff I have improved/added/upgraded so far: -Twin gauge pod with oil pressure and boost/vacuum -AEM wideband controller/gauge with sensor in the dump -King springs and KYB shocks all round (this combo feels much better than the, admittedly old, stock gear). -Braided water line for turbo -Tyres – Goodyear Eagle F1 Directional. Great set of rubber. Replaced the Dunlop Sport SP3000s that wre on it – out and out the worst type I have every driven on, except for maybe the Sumitomos I had on a rental i30 once! -Cut a hole in lower half of the airbox – not sure it does anything, but it sounds slightly better and it was free -Chrome Fairmont interior door handles – they make a nice difference to the interior of a BA -3 inch 100 cell cat into twin 2.5 inch X-Force system. Sounds decent, definitely comes on boost better, but has a habit of wanting to knock on the diff cradle once everything gets warm -Towbar – bought a secondhand factory unit. Kept the wiring plug in the boot for a cleaner look. -A couple of power ports for a Bluetooth handsfree kit and dash cam Car is now at 165k. The overall plan is to keep the car looking stock-ish and only mildly modified. I’ve been doing a heap of reading with a plan to either getting the car tuned (and at least understanding a bit more about what has been done and what I should expect) or learning to tune it myself. Going to go down the latter path and just picked up the PCMTec software. Should be a good learning experience an I’ll definitely know my car better. I feel like I am picking up the concepts of what I am reading OK so will give it a go. Ready to go in when I next get a few hours free: -PWR trans cooler – got the kit that has the right fittings but no brackets, plus bought some bar and extra hose so I can work out how I mount it all once the bumper is off. Plus a decent flush of the BTR and new filter. -Walbro 255 pump -Bigger intercooler I'll then tune to around 8 PSI, but will leave timing along or only play with it gently. Baby steps here - I want to try some things based on what I'm trying to learn, and see the result but without being stupid and having an additional inspection hole. Learning to tune seems like a good way to work on your car during a Canberra winter! Once I'm feeling like I'm on the right track, I look to upgrade the injectors and turn it up a bit more. I'll go gentle with the timing, and maybe even take a couple of tunes to a dyno with some knock detection gear and see where I'm at. I'm a long way off that though. Brakes will need some work later in the year, so am accumulating bits to go to a 322/328mm setup, with braided lines and reasonable pads and rotors. Should be better than what I've got and sufficient for where I am aiming with the car. Anyway, as I’ve said it will still be a pretty modest thing compared to some of the stuff on this forum. But should be a strong daily, good for the Snowys cruise and best of all will be largely my own work. I may well end up getting it tuned by someone if I struggle to achieve what I want to, but I want to give it a good go myself first. A couple of pics from the day I got it and shortly afterwards:
Chuck up some pics mate - will be much easier for us to suggest something useful
Here's one I prepared earlier.
The actual physics and handling wasn't too bad though. Used to love hitting 202mph in the Diablo on the coastal road, knowing that doing so meant you would crash at the next bend.
Morning! Going back to the old games is fun sometimes. Wouldn't mind a bit of the original NFS on PC.
No idea - was just laughing at the fact he thought of an old game he liked and wanted to buy it that night and would pay for delivery! Must have had a decent shot of nostalgia.
Frickin' lol
How old are your coils and plugs?
PCMTec purchased [emoji106]
FB page but no website... Read some of the Google reviews... Both would make me concerned.
Mine are loose too, even though I have the right ones. Whenever I get a balance, new tyres, etc the tyre shop just re-silicones them back in afterwards.
Haha yeah I was. Physically inspecting the diff markings is a lot more sympathetic to the mechanicals in question! My suggestion would work though...
Do a skid and see how many tyres it turns [emoji3]
Haha reminds me of when the water people sent me a letter because they couldn't access the water meter in the front yard. When I rang up, they said the notes said the cover was too difficult to remove. "You you mean the cover I just lifted with one hand, while my other hand was holding the phone to my ear to talk to you?" "Oh, um, do you mind reading me the numbers on the meter while you are there?"
I usually fill up there on the way to Adelaide so I don't have to stuff around getting fuel once we are in the city. There ain't much there! Mind you that whole stretch from the Vic border to Tailem Bend is pretty nothing. From Melbourne you could go through the Coonawarra though [emoji106]
Did lol. Helped a friend repair his eaves to keep possums out and he was convinced there were none in the roof at the time. That night one fell through the vent in the kitchen and went running around the house!
There you go - Beefmaster for the Keefmaster. Even had a full 9kg bottle with it. Frank kept himself scarce.
Pics after I pick it up tonight. Don't have the heart to try and knock the price down now.
Messaged a guy on Facebook Marketplace, "Frank", who was advertising a pretty sweet bbq. Frank sent me his number. I rang it and an elderly lady answered. "My name is Andrew, could I speak to Frank please?" "Um, no... he is my husband and he passed away a while back. What was it regarding?" "Err... a bbq on Facebook..." "Ah of course! That was me. Wanted to sell a few things but I don't have a Facebook account so I used his."
Won't make a difference. The issue is the rear sensor O2 sensor realising the cat isn't doing its job like the factory one. I'd ring a tuner and ask them to switch off the rear sensor in the factory tune. If that is all they are doing, it shouldn't cost too much more than the software credits they need to licensed your VIN. I reckon that will be cheaper than installing a factory cat and you get to keep your nicer exhaust.
Happy Easter everyone! Good weekend so far! Church on top of a mountain with port and buns instead of bread and juice on Friday morning. National Park yesterday, plus fitted hydraulic disc brakes to my mountain bike. Bugger to bleed, but so much better. Eggs and stuff with the kids today, brunch at a nice spot with friends tomorrow. Only downside is I used one of those headlight restoration kits on the Kluger and it looks like crap! Will have to bat my way out of that one sometime today. More sanding then some toothpaste I think. Will seal it all afterwards so it lasts.
Conversion xr6t's NA to T conversion
El Andrew replied to Conversion xr6t's topic in Ford 4.0L N/A Discussion
Lol that meme has more punctuation than the entire thread- 67 replies
- 1
- wiring loom? computer ?
- conversion
(and 4 more)
Tagged with:
Haha sorry mate just being stupid. Bit of a joke around here that any problem can be traced back to diff bushes.
