59
Articles
Media Demo
There is no shortcutting this. The ECU, with its boost and map pressure sensors, is already effectively an electronic boost controller. If you had a way to trick the ECU you would be adding boost without the required fuel and timing map changes. This will very likely break your motor. The only safe way to add boost is to get the car properly tuned which will update all if the required maps in the ECU. While you can do this on stock hardware, it would make sense to also make any supporting hardware changes (especially exhaust and injectors) you are planning at the same time, so you don't have to pay for another tune later.
On my old EL I bought some lights that fitted inside the bumper openings and made brackets up to suit, so no cutting of the bar all. Not sure whether you have BA/BF/FG but on any of those, you could probably trim away the various black plastic grills and fit something without too much surgery to the actual panel. Are you looking for lights to actually use in fig, or more just an appearance/DRL style thing?
That gauge is in inches of mercury, not psi. 20 in/HG is about 10 PSI.
I used these ones and they have been great. Can get in different stitch colours to match the rest of your trim. https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com.au%2Fulk%2Fitm%2F153746665225 That link is the handbrake boot for the FG, but they do auto shifter boots too and different models.
Negative Fuel Trims at Idle
El Andrew replied to El Andrew's topic in Fuel System & Induction Workshop
Finally got around to sorting this. Pulled the fuel module out, as last time I'd had to reuse some fuel hose and wanted to have both lines using the proper flexi stuff. Drilled out the fuel return thing in the bottom of the cradle to 4mm But I also noticed that the return port in the cradle was blocked. Not sure if there is meant to be something there or not, but either way it wasn't passing any fluid. So drilled that out too. Before and after pics below. I now have positive fuel trims (remembering that I fudged my low slopes to tune around the issue temporarily) so think I have resolved the fuel pressure issue. I'll do a few km to make sure the trims continue like that, then flash the correct low slopes back on. -
As a reference, I have a thermo switch on mine to kick in at 85 degrees, and a light to tell me when it does. In the past year, I reckon it has been on twice. Once on a 40 degree day after a long drive when I was circling the car park. The other was giving it a hard time in low gears through mountains on a warm day. But my car is turbo and modified, and the cooler is inside the bumper in front of the driver's side front wheel. And with the factory heat exchanger imagine you'd be seeing temps over that anyway. NA car with the cooler in front of the radiator - no worries at all with no fan.
Combined States Snowy Cruise 2019 - November 22-24
El Andrew replied to EvilDaifu's topic in New South Wales
Bunch of bald pricks -
You can't just clear the sensor code, you need to disable the rear sensor so it doesn't recur after a few hundred KMs. Part of the rear sensors job is to check if the cat is working correctly, which it doesn't when you don't have one
Get it scanned for fault codes so you know what is causing the check engine light. First guess would be that if you had a new cat installed, they didn't switch off the rear O2 sensor - but seems a bit of a simple oversight. When you say the tuner cleared the codes, was it giving codes on the dyno that were then cleared before you took the car? Probably best to go easy on the car until you know what is causing the fault.
Great to meet you and Ev mate! And I agree - top work as always Gaz. By my calculations, given their respective populations, ACT having four people on the cruise is the equivalent of NSW and Vic providing a total of 70 people. Maybe next year... -
So I was feeling like the rear wasn't quite right and gradually was hearing a knocking that ended really loud. Was right under me, so was suspicious of the control blade bushes. Just crawled under it - me thinks they are well and truly dead... -
Interesting! I think I was 15.6 on Saturday on 98 as a comparison (Tumut to Jindabyne) Barely noticed you refuelling so wasn't too bad doing the trip on E85. You should do the drive a couple of weeks before with a trailer and hide some caches if E85 Jerry cans at all the stop points! -
We were saying to the guy at the Banjo Patterson Motel that the car park ramp was a bit touch and go for our cars. He suggested, seriously, that they have an overflow carpark over the road that we could use. Took a pic of it this morning. Ain't no one gonna take their car in there... -
Hope you guys all had a good cruise and/or trip home today. Sorry Pookey and YLD that I didn't catch you when I left. Great trip once again. Yep, bulk cyclist groups with support cars on the way home. Actually enjoyed it because rather than being on cruise the whole way, I had about 20 opportunities to accelerate from 10 to 100 [emoji3060] -
They were ok - spoke to one of the guys yesterday. My dad has a 1976 Alfetta that I learnt to drive on and has since been restored, and is in the SA Alfa Club, so had a good chat. -
ACT Alfa Club was staying at Tumut on the same motel, and saw them again at Scammells lookout -
Yeah it sucks you guys couldn't join us. Next year! -
Pretty decent. Bit of traffic which was annoying depending on where you reached it, but not too bad. Some ripper corners. Think I destroyed my control blade bushes. Huge clunking under my arse whenever I loaded up the rear suspension turning left hard. -
All checked in at Jindabyne -
Had to read that twice - thought you were saying that Matt smells fresh this morning... -
I'm at Coffee Pedaler in main street if anyone is looking for breakfast -
Attempted stowaway. Would probably spew in the corners. Actually, his name is Twistie. Maybe he was born for this. -
Yep, see you later guys! We will miss you@k31th and@rab - catch you another time. -
We should be good I think - electric BBQs and gas BBQs in parks are ok https://www.rfs.nsw.gov.au/fire-information/fdr-and-tobans/total-fire-ban-rules Oh wait, need to have a responsible adult present...
