Ford_Power
Contact Methods
  • Website URL
    http://
  • ICQ
    0
  1. That's a pretty good roster!! Up here it's 28 days on, 9 off - site standard. We should catch up for a bite and a drink when you're up here next. Where do they put you up when you are here?
  2. Up @ Woodside's Pluto LNG plant. Haha and yeah I survived... The food from Roadrunners really is a "sometimes" food!!
  3. Seeing as it's the two year anniversary of your comment to me Mike, I see it fitting that I reply with "Rusty Trombone" to celebrate the occassion. HOWEVER, I STRONGLY suggest that anyone who reads this comment of mine, looks up "Rusty Banjo" on urbandictionary(dot)com for a good chuckle. I've got to give Mike the credit for this one. ;-)
  4. Damn! We are right around the corner then! I was at Roadrunner's Cafe about 15 minutes ago getting some brekky
  5. Up in Karratha Luke! Can you PM me the details too?
  6. Definite maybe too! Mike - not back in Perth yet!!!
  7. Yep - It's Ross! Still cruising around in the G6ET - I love it! I haven't been on a cruise in YEARS! About time I headed out for another one! Try get Ninka along... Newl... be good to see you too! What ever happened to Nick with the XR8?? I might try get Steve along too - he might like to ride with one of us if he doesn't want to bring the Fairmont Ghia down...
  8. I vote the 20th too - it's the only date I can make! I should also point out that any date between Feb 20 and March 06 would also work for me! Luke - It's been a while mate! Wouldn't mind catching up to say Hi! What is Allan (ninka) up to these days??
  9. The factory sat-nav DOES play through the vehicle speakers. It may have been difficult for whoever was doing your retrospective install to do it as per original factory spec.
  10. A slight thread-mine here.... But... I have just come back from overseas and after having my G6ET sitting there for 9 weeks, it fired up perfectly first time. You could tell it wasn't a 100% clean start, but it was 95% clean start. My G6ET is a Feb 09 build.
  11. Zap, How did you get Ford to replace the turbo oil feed filter under warranty? Unless one can prove it is "faulty" I wouldn't think Ford would replace it?
  12. Unfortunately, its not just a simple straight coil return spring. Its a spring that is wrapped around the shaft of the pedal pivot with "arms" that push against the pedal itself, as well as the the pedal box.
  13. In reality, both wheels may well break traction, but there will always be one wheel spinning more than the other - because of this, the TC system will still operate as per what I have written in my earlier post. Assuming that they were spinning at same time, (eg LSD-equipped car, and LSD fully locked) the engine power will be reduced via throttle / spark cut in order to stop the wheels spinning.
  14. Actually, its not that bad - the clutch pedal assembly comes out separately. There is no need to remove the dash.
  15. You're not going to like the answer, but you cannot buy the clutch pedal return spring as a spare... you have to purchase the complete new pedal box - crazy I know!!
