atrovato
4 Neutral
  1. okay so after ford having the car and testing it they snaped the input shaft and the transmission had to be replaced , was under warranty for paid the extra for a built one , got the car back from them saying the problem had been fixed and that it was purely the transmission , once again ford has failed at there job , and was still doing it after a 7k bill that was forward onto the car yard I bought the car off and then I took it upon myself as you said I work at autobarn and bought a cheap nasty set of coild and tested them that night and success not one fault so I ran around on them for a few weeks just to make sure it had fixed my problem and I then made ford give me a set of genuine coils , you could see the cracks down the side out 5 of them , all is good now car makes 419rwkw on e85 daily , cheers for your help
  2. wow really coil packs, would never have thought ? ill try what guy above you said and maybe try clean the abs sensors, apparently they can get clogged up etc and its free , will keep posted cheers
  3. hey guys, so just picked up my bf tornado zf 6, its all standard, problem im having is when I put it under load LIKE A FAIR BOOT the gearbox seems to be engaging neutral and then drops back in to gear, dash lights come on mainly ABS , then the speedo drops out , have had it on a snap on scanner and come up with U1900 (ABS CAN communication) and U2514 (Missing message), these codes only seem to be popping up in engine, cluster and abs modules but not transmission , this is happening and all drive types, like normal D, performance and semi auto.. wandering if anyone has had this happen or know of anyone that has had it happen before, any input is much appreciated
