Stu.
1 Neutral
About Stu.
  • Birthday 13/12/1974
Contact Methods
  • Website URL
    http://
  • ICQ
    0
  1. Happy Birthday Stu.!
  2. Happy Birthday Stu.!
  3. Happy Birthday Stu.!
  4. Happy Birthday Stu.!
  5. Happy Birthday Stu.!
  6. Might be a good investment but whats the point? A car you dont drive, park it in the garage of the designer house you dont live in. Spend $30 thou or so on a replica and enjoy building and driving the bastard.
  7. Im with you Dag's Its a waste of everyones time Some people filled it out, some donkeyed it. Not to metion the thousands of people who arnt really here. Im sure they all filled it out. Next time ask for a privacy envelope. When they come to pick it up, they tick you off the list and no ones the wiser. As for court, that just proves how pathetic this world is. 'You didnt fill out the form and Im dobbin, your gunna be in trouble'
  8. Stu.
    Xr6t Diecast
    Only ever been able to find XR8,GT and utes in 1:18. XR6\Turbo in 1:43, I have one in Acid Rush. Someone on here has painted one and from the pictures looked good.
  9. 2000 Jeep Grand Cherokee (her car) No mater how good the Turb is you still need a V8. 4x4 to boot. Not as fast as the T off the stick but sounds awsome with the foot in the carpet.
  10. Fuel filters worth a look. Mine would wind up slowly ok but if you gave the pedal a good hit it would some feel like the hand brake was on (low power, no boost). Other times it drove like the trac. control was perm. on. Stu.
  11. Rickshaws MAD day at Swansea tommorrow (Bargoe House). I'll be camped there tonight for a couple weeks. If anyones up for a cold one tommorrow? (Black JEEP, camper) Cheers Stu.
  12. From RTA Web site. Minor changes to wheels Wheels up to 26mm wider than the largest optional wheel recommended by the vehicle manufacturer for the vehicle can be fitted without the need to notify the RTA. The outside diameter of the wheel and tyre combination must be no more than 15mm over the largest diameter wheel and tyre combination specified for the vehicle and not more than 15mm below the smallest diameter wheel and tyre combination specified for the vehicle. Replacement wheels requiring an engineering certificate Wheels that exceed the diameter and width limits for minor wheel changes must be assessed by a signatory. If the signatory finds that the wheels are safe for your vehicle, you will be issued with an engineering certificate. There are limits on the size of wheels that can be certified by a signatory. See below, http://www.rta.nsw.gov.au/registration/dow.../vsi09_rev4.pdf This rule applies to trucks and busses,..........cars? Ground Clearance A vehicle or combination must have a ground clearance of: a. at least 100mm at any point within 1 metre of an axle; and b. at least one-thirtieth of the distance between the centres of adjacent axles at the mid-point between them; and c. at any other point - at least the distance that allows the vehicle or combination to pass over a peak in a road, the gradient on either side of which is 1:15, when the wheels of one axle of the vehicle or combination are on the slope on one side of the peak and the wheels of the next axle are on the slope on the other side. I was led to believe it was 100mm between the metal bodywork and the road. There was/is also a minimum headlight height. 520mm spirngs to mind but dont quote me.
  13. Stu.
    Oil Leak
    Had a leak at the turbo end. Couldnt tighten it though as I could only get at one bolt head. Pulled the turbo out/off replace upper and lower seals. All good. The manifold bolts needed tightening anyhow.
  14. hey bogan393, U a staff club member? When I get a moment I want to organise a hook up at Bargo. Local cruise and lunch down Swansea. "gotta work" yeh! Im doin Sun. Dist. Tech. M'brook Stu.
  15. Singleton Street Machines have got their annual show on the 25th-26th Nov. Show n Shine Sound Off and Grass Events (driving) Dunno about Dyno. I'll check with Mick tommorrow. Stu.
