Puffwagon
Gold Donating Members
    792
  1. Puffwagon
    Fuel
    Fortunately as it was such a "low" power car, being n/a, it was super easy to log it on the brake with winlog. I think it took only 3 laps around the block at various loads to fix it up. It ended up with a ported and modded head, zorst and comp was 220psi. It made stuff all gains running e85 over 98 according to my butt even with modified timing and fuel to suit. I guess the compression wasn't there for e85. Tl;dr another guy measures his engine gains with his butt hole. It pulled a whopping 6 secs to 100 mostly done in 1st! Btr ftw!
  2. Puffwagon
    Fuel
    I had a stock AU falcon that run 9.8:1 afr up top when it was stock. Factory tunes can be dogsh*t.
  3. Puffwagon
    Fuel
    With my pfc tuning I found I had to remove about 4 degrees up top changing from 98 to 95 on a tuned jap car. I had to pull around 8 degrees running 91 to prevent knock. It was slow and it sucked and would recommend 1/16. The same timing was used in all tests. 95 can go in my wife's 2012 lancer and I'll continue with 98 or better in my ford. You have a valid point however MattyP, a car will only run as good as the timing allows. If it won't knock on 95 then a slower burning fuel like 98 won't be better and could cause more heat in some cases as the longer burn will continue to propagate further past tdc.
  4. Jeez I just reread what I wrote before. Of course the car is already tuned... We all have our hurdur moments I spose. Insert lame excuse here [ ]. @Ralph Wiggum Shouldn't you have told me I was being a dumbass? In any case just read the tune with a hp tuner interface and save it as a known good tune. Then mess around with tuning it yourself after you have an idea of what to do. You will get answers on the hp tuners forum if you aren't sure what stuff means. Or just be happy with the car as it is and save the $1000 for beer!!!
  5. ^whs
  6. I bought hp tuners and tuned my car with no prior knowledge of hp tuners. I have tuned several other types of ecu over many years so for me at least it was just a matter of wrapping my head around how the ford pcm works. If I was in your situation I would buy hp tuners, scale the injectors so it's drive-able then take it to a professional (without boosting it) and get it tuned. This way you get your car tuned back to it's original power level but you'll have the ability to start making small changes knowing that you can always fall back to your safe tune. It's pretty easy to break a motor when the power is getting up there though it's a bit harder to break with e85.
  7. Heh I just read jets post. That's a thing but let's hope it's ok.
  8. Function over form I reckon. If it works how you want it to then it's all good. Try turning it down to gate pressure and see how good it works.
  9. Still pretty cheap bolt on power. Fuel, zorst, cooler, intake, turbo, tune, bam 600 rwhp. Replace other bits as they break
  10. That's what I would have said. It will have a giant horn on top and stretch out to the 95lb mark or so. I think...
  11. Maybe. There is a difference between apathetic parenting and actively teaching your kids to be evil. I think the really bad kids mostly have parents who teach them to be scumbags rather than them learn it naturally. Clearly there are exceptions to this idea. I don't think society currently has the capacity both in knowledge and technology to make a fair decision on who should receive such a license. What's that movie where people get arrested based on crimes they may commit in the future?
  12. Yeah I figured I'd set the page up with the parameters in, as it is a pita to work out how to setup without being familiar with some of the variables and wheel sizes etc.
  13. I think more like 3 eyes for one eye.
  14. Oops I meant with the ford turbine housing, not in. Hur dur Also thanks to the mods who cleaned it up. I forgot about that thingy
  15. I dunno guys. Even when I was a kid I knew the difference between right and wrong and acted accordingly. I sure as hell wouldn't crap on someone's rug and the fish thing...that's some mentally ill sh*t right there. They were all caught the same evening and apparently the police are charging them with a range of offences and child welfare is getting involved with the families for counselling.
  16. She is a teacher.
  17. My wife's workplace was broken into over the weekend. They stole $20 petty cash, one camera and I think an iPad as well. They weren't content with that though the little cvnts. They threw eggs all through one room, tipped 20 litres of paint on the walls ceiling and floor, smashed a lot of glass, wrote crude words on the walls and generally trashed the place. Still not happy with their handy work they pissed and shietted all over the rugs which had to be thrown out. As if that wasn't bad enough they smashed the fish tank and cut the fish up, presumable while still alive, with scissors. The bird was missing and I guess it either escaped of suffered a similar fate as the fish. What the FUARK is wrong with people?
  18. Holy links batman!!! I used this calculator a while back when I was deciding what compressor wheel I should use. It takes a bit of time to set it up so it's accurate but I set it up roughly to give people an idea of what it does. Obviously compressor maps will need to be obtained from other sources to give clearer results as these are all bw maps. The results I got from this calculator are what helped me decide to use a genuine gtx35r compressor wheel rather than the t04z wheel, which I thought may be very close to being uncontrollable in the ford turbine housing. Tl;dr It's a turbo majigy calculator
  19. Howdy everyone, it's raining and cold today, boo!
  20. Heh yeah it's kind of hard to pick up inflection over the internet!!
  21. Only busting your balls mate cos no one wants to see you hurt your new motor. As long as you don't boost it until it's tuned, you'll be right.
  22. Morning everyone. Just me and the 22 month old daughter at home today. We're sitting in front of the pc (obviously) and she is demanding that we watch babies on youtube... No cars, no game, no burnouts, it's gotta be babies!
  23. Im still around 20% fat so I'll end up at 95 to 100kg once I'm where I want to be in a few years.
  24. I'm a stay at home parent so most of my time I'm stuck at home. I gotta do something to stay fit. I have a bunch of gym equipment and have written a couple of different programs to help me get stronger as well as gain muscle and lose fat. So far I've pretty much been recomping for the last 3 months. I workout between 3 and 5 times a week. I'm 6ft and my weight has remained stable at 104kg. Macros are 94 fat, 211 carbs and 281 protons for a total of 2810kcal. So far I'm still losing fat so I'll keep it like this until I stop losing it then drop my calories a bit.
