Puffwagon
Gold Donating Members
    792
  1. That link is to the boost sensor. If you want to use that you can but you will need PCMTec to be able to utilize it. You don't need to upgrade the TMAP.
  2. Yes I suppose I could. I recently bought a whole bunch of wraps, knee wraps, elbow wraps and sleeves and also wrist wraps. I have been wondering how the knee wraps will help my squat.
  3. I should really go do some gymming but I cbf. I'll restart in 3 weeks once my elbow has had more time to chill. I think I'll go out and clean the shed though and organise it for future activities.
  4. Hiya!
  5. Yeah I knew I was forgetting something
  6. Yay Friday
  7. Yay Thursday
  8. I've got something planned, I'll update when it's done.
  9. For how easy it is to go over them for a re-torque, I would just include it either as needed, when you're in there doing something or every 6 months.
  10. Make sure you play it with the missus nearby
  11. You can swap one injector for another for a quick sanity check. You may as well just chuck another second hand one in there while you're at it, its up to you how you approach it.
  12. No cloud save?
  13. Had a look, the manifold wasn't tight enough. Torqued up the loose bolts which was most of them, started the car and no ticking. I should have checked them when I swapped the turbo recently but I didn't. The irony is I knew they would need retorquing due to all the new parts put on it, it having heat cycled and settled into place.
  14. Yay Wednesday
  15. If you drop it to 1 bar it might run ok. Better to just swap out the stuffed stock injector, they are dime a dozen and someone will probably sell you a set for next to nothing.
  16. There isn't a lot of difference between a turbo box and a na box, they have a different amount of clutches in the clutch packs. The place where the na box will fail early is the 3>4 shift due to there being less clutches in the E drum and the clutches being about as big as the palm of your hand.
  17. It has its place, especially when you have sons
  18. I downloaded South Park, the fractured but whole, on the ps5. Apparently pressing the fart button repeatedly annoys the missus.
  19. Tick tick tick tick tick tick tick... Looks like I'm having a squiz at the turbo or manifold gasket tomorrow.
  20. Yay Wednesday
  21. Yay Monday
  22. Start a thread so you can keep all your info in one place. Makes it easy to find and has better community engagement.
  23. I've increased the boost on the na+t territory and it makes a bit over 300awkw and 600nm on 15psi. As a result the trans needed an update to the tune, which I did this morning. Once again the shifts are quick and crisp and you wouldn't know it's an na trans in there. I think this is where I'll stop the increase in power, it is a na engine after all. When the time is right I'll do some minor engine work to it so it can handle all the boost, but for now it will do.
  24. Yay Sunday
  25. Yay Saturday
