Puffwagon
Gold Donating Members
    753
  1. Had a look, the manifold wasn't tight enough. Torqued up the loose bolts which was most of them, started the car and no ticking. I should have checked them when I swapped the turbo recently but I didn't. The irony is I knew they would need retorquing due to all the new parts put on it, it having heat cycled and settled into place.
  2. If you drop it to 1 bar it might run ok. Better to just swap out the stuffed stock injector, they are dime a dozen and someone will probably sell you a set for next to nothing.
  3. There isn't a lot of difference between a turbo box and a na box, they have a different amount of clutches in the clutch packs. The place where the na box will fail early is the 3>4 shift due to there being less clutches in the E drum and the clutches being about as big as the palm of your hand.
  4. It has its place, especially when you have sons
  5. I downloaded South Park, the fractured but whole, on the ps5. Apparently pressing the fart button repeatedly annoys the missus.
  6. Tick tick tick tick tick tick tick... Looks like I'm having a squiz at the turbo or manifold gasket tomorrow.
  7. Start a thread so you can keep all your info in one place. Makes it easy to find and has better community engagement.
  8. I've increased the boost on the na+t territory and it makes a bit over 300awkw and 600nm on 15psi. As a result the trans needed an update to the tune, which I did this morning. Once again the shifts are quick and crisp and you wouldn't know it's an na trans in there. I think this is where I'll stop the increase in power, it is a na engine after all. When the time is right I'll do some minor engine work to it so it can handle all the boost, but for now it will do.
  9. The lad has his 12th birthday today and he wants steak. Haha I taught him well
  10. @k31th I filled out a bunch of information on a webpage pdf and the farker didn't save to pdf which lost me all the work. Is there anyway of recovering that data?
  11. I would send noods but I don't think there is enough data on the internet to support the file size required for my magnum dong
  12. Inb4 fluff posts an update pic and keef asks for noods
