LTSBGY
Contact Methods
  • Website URL
    http://
  • ICQ
    0
995 profile views
  1. cant find anything like that on ebay. can you point me to it? thanks
  2. Thanks. How do I get rid of the aux whine? I read somewhere that someone on the forum can do this?
  3. I want to connect mp3 player to ICC. Do I just purchase that AUX plug from ford? What about the aux whine that I heard about, will that be there and will I have to get that sorted as well? Does it matter which ICC you have, whether its 6 stack cd or just basic with single disk? Thanks
  4. that's just the PC no screen
  5. mini ITX was wat I was talkin about. under 1000 bucks with windows installed and stuff. Is that a good price?
  6. They are mini itx.
  7. Found a guy who is selling these mini PC's which you can plug into cigarette lighter coz it has 12v power supply. Its tiny and can fit under the seat. Does anyone know how I would connect it to the ICC to play music, vids etc?
  8. Just wondering Can the E-gas be tuned with edit?
  9. The problem was due to the wastegate actually slipping down some how, not sure if it was factory fault or not but because it had slipped down it was hitting the wall of the turbo and wouldnt close. It took a very hard bashing to move it just a few mm so hopefully it wont happen again and if it does then a tak weld wil make sure it doesnt slip down again.
  10. hey guys just a thanks for your input. the problem ended up being the waste gate was stuck open.
  11. Yes was custom tuned with edit and managed 230 rwkw with 6psi. Tune is meant to pump out 12psi and have 270rwkw +. Boost comes in late after 4000 rpm. Tried another boost controller and that wasnt problem. If its a sticky wastegate how would I go about freeing it up? And im guessing the only way to see if its the actuator is to change it, roughly how much?
  12. hi I have an 04 xr6t with a xforce exhaust had it tuned and it wasnt boosting over 6psi checked the cat and it was fine I havent checked the turbo we even tryed a boost controller what else could it be apart from the turbo??? thanx
  13. LTSBGY
    Edit Problems
    I felt no power increase after the flash and the turbo doesn't kick in at all after 3000rpm. Nah, I don't have a boost gauge but I'm thinking about getting one now. ← Like the others said, check all the pipes. If everything is ok then perhaps try flashing in another tune p2, p1 or which ever u havnt tried yet.
  14. LTSBGY
    Edit Problems
    Yeh the power light should flash and the slot you flashed in the light should stay on. Can you feel a power inscrease when you flash in the tune? Do you have a boost gauge? Nesh
  15. Are you using the stock cooler with stock plumbing? If you are than you have to block the turbo intercooled induction side aswell. What would you use to block that off?
