Blkdiamond
  1. NVT that looks spot on, exactly the hight I'm after! How does it drive/handle? Any camber issues with the front for the alignment?
  2. Thanks guys!! I haven't driven it much yet.. I have had many lowered cars and I don't want to end up with a low pig. Iv done a bit more research and supposedly there is a 15mm front King on the market and a 35mm rear which would be ideal I think. not to low but enough to give it a good stance and level it out.. Pixi do you know how many mm the (sssl rears and ssl fronts) are? There is hardly any speed bumps where I live and nun are to steep, I'm sure it would be different if I had a big from lip but I thought the G6E bumper was somewhat high of the ground and 20-30mm wouldn't be a issue (speculating) My budget isn't huge, Ideally I would go coil overs all around but ye that's not going to happen. Kings go for around $450-$550 NZD for 2 pairs. Thanks again
  3. Hey guys, Just bought my first Ford.. Its a G6E-T 2011 on factory 19's. I want to lower it about 25-30mm max from standard hight. I have 2 concerns, 1. I want it to sit flat NOT nose down 2. I have been told there lower then xr6's by apx 20mm so if I get a lowering kit for a xr6 say 30mm il only come out 10mm lower then I am now?? Any help appreciated, I am in New zealand by the way.
