ToXic BF Beast
About ToXic BF Beast
  • Birthday 09/07/1980
    Dee Why
  • Interests
    Boost
983 profile views
  1. Well I found one on eBay.. $51.. its called a ROCKER COVER VENT AIR HOSE.. better off fabricating my own I think
  2. thanks k31th, is it a big deal to leave it for a couple of weeks.. when the engine is idle and I move the hose around it doesnt seem to effect the engine idle in anyway.. where can I order a new one (pls dont say ford) ,, what would a newb like myseld call this hose?
  3. Hi guys, Need help, what would you call this silicone hose going from the air intake manifold into the top of my engine? its frayed/split and just wondering what its called to replace.. im guessing its just an air hose but I really dont know enough.. http://s1376.photobucket.com/user/jeabmasnok88/media/bf xr6t_zpsgew0sfis.jpg.html thanks everybody
  4. Happy Birthday ToXic BF Beast!
  5. F! So no Katoomba cruise today???
  6. Does it sound like this Boost69 ? http://youtu.be/Vd3JSFapspM Can that forskin program actually fix the problem? (Providing it is my SAS) I've only played around with TORQUE but it doesn't read the ABS.
  7. Yup! cyazzz all there
  8. Is it 'FORScan lite' your using? For $6.49 @ AppStore?
  9. How did u pick up the ABS sensors? They don't show on Torque or Dashcommand. Does forscan give more info? Ford want $125 just to scan
  10. Does anyone else's boost show a constant 5.5 psi? I tried playing around with the boost settings where it suggests -14.7 or 0 or 14.7 but doesn't seem to change anything..or is it just a ford thing? Also is it worth getting a 2nd OBD for iOS? I have a "ELM327 Super-mini OBD2 Bluetooth" But it doesn't work on iOS. I've had to ninja my sons Android but droid tablets feel so laggy. - Are you guys using Androids or iPhones?
  11. Hi G6ETNZ, I had a similar noise. Apx 30cm from stopping.. & when I was reversing slowly with my foot on the brake. It turned out it was the wheel sensors thinking I was out of control. I didn't get any warning lights on the dash either.. Easiest way to see if it's ABS related just pull the ABS fuse out & go for a drive. This disables your TCS & DSC aswell so you'll see all 3 warning lights illuminated. Might make it easier to point the mechanic in the right direction
  12. I had this problem when I bought my BF. It would clunk and grind in the pedals just before coming to a complete stop. It would also do it pretty bad reversing with my foot on the brake. I just took my ABS fuse out =No more clunk It ended up being a faulty front wheel sensor but it saved me having to play 'guess the noise' with Ford
  13. My TCS light came on permanently & brakes were spazzing out every time I came to a slow stop or crawling in traffic (prob wheel sensor, brake pedal switch) I just pulled the ABS fuse out and goodbye clunk.! However, now I obviously have no TC & DSC.. Which is fine. But how bad is it drive without ABS? Not track just road driving Not to mention the 3 new warning lights - The scary red exclamation mark.
  14. Hi TURKLE Did u ever get this issue sorted?? Mine has done it since I got it last yr (BF XR6T) Only just realising how much I hate it The "clunk clunk grind grind" disappeared for 2 days, every thing was quiet and... Like a normal car. But the noise is back ( my TCS light came on & couldn't be switched off) So I'm 99% they're related Mine goes mental every time it come to a slow stop or starting to crawl like in traffic. Let me know mate Anything to avoid the Ford dealers
