3 NeutralRecent Profile Visitors
1,017 profile views
Yeh its strange, never lose coolant and the temperature is perfect.
Is it normal for coolant to 'bubble' after turning of the car. Its like a bubbling sound that lasts a minute or two after turning the engine off. I have bled the system with heater on full up to operating temp, and theres no visible coolant leaks or noticeable loss of coolant. Another thread suggests its perfectly normal on these cars ?? I doubt that. Anyway I guess I'll try replace the reservoir cap next....
I've just done engine oil, gearbox oil and earls turbo feed. The car drives smooth as, and no error codes Im in SA, Heinrich Performance seems to be the choice of most and he's close, so that's who Im planning to use.
Yeh well the plan was to eventually go injectors, hf cat, fuel pump, intercooler, tune. But that's a bit further in the future, for now I have an x4 doing nothing and I just want a custom tune. I'll give the tuner a ring, but from what I've heard a custom tune shouldn't be too $$$
Ahh ok I was mistaken :( Yeh If I was gonna buy a 'mail tune' online I may as well pay the bit extra and get a custom dyno tune locally. Thanks for the info Rab.
Hey, So I just bought a brand new SCT x4 flash tuner, for now I just wanted to use the generic tunes and get a custom one later when I do some mods. I went to load a pre-loaded tune onto the car but it says there is none for this vehicle, with the message 'VEHICLE UNSUPPORTED HACCKJ7* contact technical support'. The car is a completely stock bfmk2 turbo, and the x4 is brand new AU edition. Is there something I'm doing wrong, can anybody help ?
160000km my 2nd synchro sucks as well, 3rds OK, rest are smooth as silk.
Nvm I guess that's for people with traction control on the dash! silly me
Hey guys, Installing a boost gauge and looking to take the illumination 12v from the traction control button as I have been told. I have the icc out but I can't work out where the traction control button gets its power from, as far as I can see its all hidden behind a circuit board ? Any help would be much appreciated
My bfmk2 'apparently' still has the stock clutch and it is quite heavy, real nice to drive though. Im guessing it needs quite a heavy clutch to not slip, even at stock power. My other car (not an xr6) has an excedy H/D clutch and the ford is still much heavier. If it still shifts fine, I'd say its fine. Better than it slipping at least...
removing waterpump ?! craaap scared me for a minute haha. Yeh this is thermostat housing, I was hoping to just loosen that tab pull hose out and replace o-ring but I guess it might not be that simple :/
Ahk awesome, sounds pretty straight forward. Hope its just the o-ring and the hose isn't perished aswell.
Hey, I've got a slow coolant leak from this hose that goes into the thermostat housing. How exactly does this seal ? It seems weird that they don't just use a normal outlet and hose clamp.
Well I crossed one thing of my list and changed the gearbox oil. Used Penrite Pro Gear 70-75 and I must say it has made a difference. Definitely a bit heavier than the Dexron iii that was in their but 2nd to 3rd gear changes are much smoother now.
OK thanks for the clarification
