maxmundy
  1. Hello, I'm about to purchase RotaGRID rims with 114.3 bolt size, I'm just wondering what offset I need? Thanks guys
  2. Will 5x114.3 wheel nut size fit? Thanks
  3. Will 5x114.3 wheel nuts size fit my xr6t?
  4. Okay, so if the piston on your aftermarket BOV isn't fully covering the whole that the pressure comes out from while boost is on does that mean you're losing boost and power? Like if on idle you can see the bottom of the piston going up and down leaking
  5. Tasmania, it's actually cheap here for one to buy for 12,000. Maybe it's a good idea for future ideas to sell over here guys?
  6. Hey guys! I own a 2003 BA XR6T, 100,000 kms, it is immaculate with leather interior, manual, sounds and goes great! Since then the only modifications would be a 3" turbo-back exhaust into a twin 3" blast pipe muffler delete, and a Turbosmart BOV. What would you say it's worth? I paid $12,000 for it 6 months ago. How much did you pay for your XR6T?
  7. Okay mate thanks
  8. Yeah I will give it a try, thanks!
  9. I also usually have the vaccum lines into the top of the BOV.
  10. I have purchased the duel port Turbosmart BOV. Yesterday it was idling, I disconnected the vaccum line and it seemed to idle better when the vaccum line wasn't blocked? Suggestions? Should the vaccum line be in the BOV, blocked off or open? Thanks.
  11. If it isn't the battery, any other suggestions?
  12. Okay so what will happen, I go to start it in the morning, it will start up, and 2 seconds later it will stall pretty much instantly. I then try to start it again, after turning the key all the way it just has a few light clicks, it doesn't try to turn over. After it has died it also comes up with a little hand icon in the dash flashing and occasionally the aircon and lots of other electrics will stop working. It's so frustrating, I will replace the battery ASAP. Thanks guys.
  13. My car right now is doing the exact same thing! Have you replaced the battery? What's happened after that?
  14. My car does this, but occasionally it will just start then die and then go tick tick tick
  15. Okay thank you Stever. [emoji4]
