QIK06T
6 Neutral
686 profile views
  1. Just to conclude. The fluid was not leaking so I went straight to Ford and got the switch for $29 and issue resolved surprisingly Sent from my SM-G925I using Tapatalk
  2. What does johnny charge for a kit like that. Airbox is 3 inch not 4 is it? Sent from my SM-G925I using Tapatalk
  3. I couldn't see any fluid in the mastery cylinder. I opened it and ask I could see is 2 rubber boots. I think one of my brake lines has come loose. Will investigate it on the weekend. Sent from my SM-G925I using Tapatalk
  4. Hey fellas got a problem. Was driving home in my FG F6 on the highway today when the DSC fault came up. Then started the car at home later and the DSC and ABS fault came on. When sitting in the car at idle I can now hear a noise that seems to be coming from under the car but its not too loud that you can hear it from outside. Haven't changed tyres or done anything recently. However I must note that there was heavy rain in sydney today if that has anything to do with it. Is this a common fault. Any fixes? Sent from my SM-G925I using Tapatalk
  5. 23 - 2011 FG F6 Sent from my SM-G925I using Tapatalk
  6. Have you had a look at your diff bushes lately Sent from my SM-G925I using Tapatalk
  7. Yes Dekas. So is that normal or should I look at replacing them or just one that's bad.
  8. So I've noticed only when my car is idling, that there is subtle pops coming from my exhaust. My brothers XRT doesn't do it and we both have x force exhausts. Mine is BF and only other mod is 60lb injectors and (suspected of the shelf tune) from previous owner. I figured it'd be a better idea to record a video, so here it is. Try listening with good quality headphones at mid level, were it's most noticeable. I don't think it's normal and no issues under higher revs. XR6 turbo exhaust noise: http://youtu.be/C-VNgv0lRQY Cheers Ed
  9. Interesting point, I'll have a look. What more do I need to know about going short motor.
  10. I'd like 350 which I think is the max I can make safely?
  11. I'd like to but I think it's a bit hardcore for my application of the car. Won't be going near 400 killer wasps.
  12. Gday So I'm wanting to discover my options regarding my BA motor and how to get it up to spec to typhoons motors. Will I need something like this ... http://pages.ebay.co...EBAY-AU&alt=web out of a bfmk2 turbo or perhaps a whole engine or just build rods and pistons. I'm particularly looking for the most cost effective approach. Thanks
  13. Alright lads, sorry I've been busy with uni. What are my options regarding getting my car back up to spec. Will I need something like this http://pages.ebay.com/link/?nav=item.view&id=281425422617&globalID=EBAY-AU&alt=web out of a bfmk2 turbo or whole engine or just build rods and pistons. I'm particularly looking for the most cost effective approach.
  14. I didn't pay too much for it though under 9K
  15. Hey guys, it was a loose bolt at the inner toe arm passenger side, the guys did it up and its fine now. The bearing on the same wheel is also done possibly due to the loose bolt, but nothing major. Thanks
