frozenxr6t
21 Excellent
2,960 profile views
  1. Who knows what rims these are.. ive gone from loving black on white car to white on white car and want these or similar in 20s
  2. I think ill just replace the U gaskets at each end some decent sealant down the guts. I hit the limiter max 7 or 8 different occasions with 300kw. But car had 100k kms on it w ht en I bought it so who knows what life its had
  3. Sumps still in place now as we pulled sump down enough and lifted engine enough to get the pump off. I'm exchanging pumps so I needed to send mine down before they send new one unless I pay extra 275 bucks. But turned out my pump was total so found a replacement pump in working order for 30 bucks so sent it down so new one should see my place next week.. Still know tune oil pump let go first.. And I had the airbox setup back in.. But turbo side is back now and I'll be going straight to get a re tune once pumps in.. P.s sump had no gasket just sealant around the sump and block faces. But on I seen on eBay gaskets for ft xr6 turbos??? Anyone know for sure if I was meant to have a gasket in between the sump and block?
  4. broke the oil pump gears on the fg so atomic pump will on its way next week.. what a low job it was pulling that off with engine in the car
  5. nah it just went away and wasnt a problem again. sold car and havent heard anything back
  6. yeah ok if the housing was cracked it be leaking would it? cause mine isnt leaking. $1000 bucks isnt bad if that's all the damage ive done to car? it did through auto fault code but it dont seem top be on anymore when the reds are turned on!
  7. 306751 Race Oil pump, Ford DOHC 6 $1,265.00 Race Series Oil pump to suit Ford 4.0L 6 cyl Barra DO 306751-RB Race Oil pump, Ford DOHC 6 $990.00 Race Series Oil pump to suit Ford 4.0L 6 cyl Barra DO Whats the difference
  8. it would be easier top pull the k frame out for ease of the job yes?
  9. ive read and been told its something that can be done with engine in the car still so ill be pulling mine off to check the damage and hopefully I shut it down quick enough.. what price did you see pump and gears for??
  10. Mate unsure but would have been over 6500 Id reckon
  11. Yeah when my gears broke it just felt like the car hit a flat spot then went to click second and seen oil light flashing and beeping . Going to pick the old girl up today she been parked around the corner for a week nearly now..
  12. Yeah increased bypass valve by 100% or something the YouTube video says
  13. Yeah I think whilst it's off we will check bearings also. If it's stuffed it's going to cms next year sometime or sadly maybe the year after all depends on the house renovation progress. Atomic oil pump is better in every way type it in on youtube they give you a run down
  14. Who reckons it's worth trying a new atomic pump and gears on the engine and seeing if it's all ok. Worse case scenario is I have just bought the new pump and gears for the new engine if needed???
  15. Yeah I'm more after do it once do it right fix, there may we'll be nothing major wrong with my engine, it ran for max 10secs after light come on by the time I could pull over. I'm only chasing 600hp max ever so whatever my best option is I'll go with it. I want reliable 600hp but
