Jiggles
1 Neutral
  1. It's manual and yer man I always run 98 in it I just let some oil out in it it's showing a couple mm under the full line now it's running good but still has a miss
  2. I went to a mechanics shop up the road they used a computer diagnostic thing that plugs into the car any ideas wat could be the problem would it be the boost control solinode
  3. stock only has an growler intake running stock boost
  4. Hi I got an xr6 turbo about a month ago it was going good for the first week but had a slight miss on idle then I changed the plugs and gapped them right,change the coolant and oil aswell I took it up the road for a spin and it boosts fine in first but when I change to second and hit it it's like it's not runing on all cylinders proply like it's running out of fuel so I put a new fuel pump in change the fuel filter put new coils in put another set of plugs in and still has slight miss it's pissing me off I also got it diagnoised and it came up with these codes P0172 - System to Rich (Bank 1) P1506 - Idle Air Control (IAC) Overspeed Error Anyone had this problem Also if I slowly excelerate on to boost it doesn't do it But some times it's like it's not boosting need help
