JVK
Silver Donating Members
JVK last won the day on May 28 2022
JVK had the most liked content!
154 Excellent
About JVK
  • Birthday 20/04/1965
    North West Hot Hell,VIC
4,027 profile views
  1. Good info , Wish I had found this the other week when looking. 2008 G6E with the same left indicators staying on issue. Ford dealer diagnosed and replaced the stalk assembly. The vehicle was picked up and the 5min drive home was fine and parked for the night. Next morning start up same issue with left indicator , Left the car for the day and started it the following day and everything was fine again. Dash cluster might be next on the list as it did blank out and not function for a day a fortnight earlier.
  2. No you wont need any wastegate porting for that. But if you modify the exhaust with a hi flow cat and dump pipe system you will then.
  3. Looking good Mick, bet you cant wait to have it back on the road though.
  4. Yep, trans will be I <3 Bananased and need a rebuild.
  5. What sort of power did that e-gas engine make on 19psi Puff ?
  6. Was good to meet you at the drags the other day Mick. Keep at it and get that tune sorted sooner rather than later. Will be good to see you run into the low sevens or better.
  7. Check your intake manifold gasket for leaks. Read a few more threads in this section regarding missing or no injector pulse. Fg ecu will drop injector pulse on some cyls if it picks up specific coil misfire events.
  8. JVK
    help
    Even though alot of aftermarket pumps run more line pressure then a std one this is not why it happened. This was just a bad instalation.
  9. JVK
    help
    Take it back to the tuner and get them to check it out.
  10. HaHa Molch good job, now the fun stuff begins.
  11. ^^^whs^^^ wastegate more than likely not shut.
  12. JVK
    My Build
    Lol, I wish I had that stockpile of spares and had to make those hard decisions. Good to see the build is still going on. The end result is going to be fantastic to see.
  13. .7 plug gap but you are going to hit more problems with overboost with that exhaust. Ported turbo and retune will be needed. If it killed the cat there is a problem with the tune anyway or either it had a previous missfire for quite a while before being fixed.
  14. Hi and welcome to the forum. Just a quick question, How long ago have the mods and tune been fitted and done on your car?
  15. Welcome back, You may as well do the head studs and new valve stem seals and your done.
