Qik6
4 Neutral
766 profile views
  1. Keep up the good work boys looks like it would be a good platform.
  2. Good on you champ wish you all the best in all your business/ life ventures
  3. Bloody top result what power that making at the treads to run that number did he get booted after that.
  4. Funny that I was going to ask you before you wouldn't have been the bloke that needed some power for that laptop lol
  5. I don't have anything that I raced drove my stock F6 up but went up with 2 mates cars black datto 1600 and the te cortina with the Barra in it
  6. Hey Pep she sounds good at wot on the runway sort the little gremlins out and it might fall in under the 20s with that sort of terminal speed
  7. Hi Pep what colour is your car I was at snowy mountains as well, well done on the speed what time did you run the 1km in
  8. Hi P Hi Psi it is used on all throttle application (sudden throttle application) and sometimes can be a tedious process, usually and I say usally above 4000 rpm no throttle pump is needed or very little is need and as we go backwards down the RPM range more is needed .Some widebands can capture it depending on how quick they respond and positioned in the pipe the closer up,front the better. And like someone has mention just previously it's like the accelerator pump on a carby if you look down a carby you will see the pump squirt fuel down the throat same principal accept in the EFI world that figure that's inserted in transient pump is then added to your base iIDC. Hope this helps a bit
  9. Transient fuel as I know it in all the aftermarket Ecu world is another name for throttle pump basically the sudden movement in throttle opening there needs to be an enrichment otherwise you end up with a flat spot.I hope that's clear as mud.
  10. Mate you need to see if this works looks like it would be very beneficial to a lot of people using this sort of software.
  11. Rollex you can't compare the both doing it live is so much easier quicker and you see the change immediately and also you have the pin point accuracy of what load cell the engine is at whilst tuning live. if you could implement live tuning you would be a millionaire
  12. No worries thanks for your advice
  13. Yeah it's probably the end user always looking to blame someone wherever the rumour started. Lol
  14. Ok fair enough doesn't look like it will affect me all ozzy based stuff I got
  15. Yeah that's no good to you it's just in my case he has everything there (Dyno ,SCT software and I have a the box. I also heard a while ago not sure if it a rumour or not that the HP tuners used to do some weird things to the fords like switch on thermos when it wanted or other stuff that I can't remember is it true or is that just crap. And Ralph when u refer to region is that Aus and US
