RLord
  1. Hi guys didn’t end up getting that G6E Turbo that had 200,000kms just couldn’t get past the kms it had done. So still looking around for one under 150,000kms have found one that has 110,000kms on it but will see what the final price is. From inspection it looked pretty good however I did notice the pipe from the inter cooler to the turbo looked like it had a fine crack on it and could see the pipe looked a bit rough also the coolant housing had big dirty splotches in it which scared me a bit. treay81 is yours a FG? And what actually happens when the turbo fails? Can you still drive the car with a failed turbo for a little bit? Or you have to get it towed?
  2. Thanks wagon for replying and giving me some food for thought. I just am stuck in a rock and a hard place as I would love to get it but just don’t want it to become a money pit then misses would really lose her sh*t!! Honestly wagon what would you do? Is 200,000kms a money pit that will just require to much to maintain and replace bits because of the high kms? Or does it still have a at least another 100,000kms in it before turbo would need fixing and other mechanical problems.
  3. Thanks wagon, The reason I was looking toward dealer than private is cause I can trade in my currant car so all up for the dealership it would only be a change over of $5000. Yea I read about earls oil turbo line I would definitely get that is that a DIY job installing that? Was thinking I would get a trans cooler as well. Do you think it would need a new radiator though? It looks like the car has been stock all it’s life which is a good thing! Like I said I’m just worried I bought it and straight up would be hit with a new turbo which would be what 2k? And if the trans was cactus that's 5k? I would be planning on having the car for a long time down the track as I love these falcon turbo six’s and heard you can get 500,000kms plus out of them just the turbo would need replacing eventually.
  4. Hi wagon, It is from a dealer which is supposedly RACV accredited. I told the dealer that the car needs a service and he said they can do one at the dealership along with RWC but I’m just not sure I can trust the dealer looking at faults and fixing them like the transmission if it’s milkshaked or if the turbo needs a rebuild. I’ve read mixed reviews from this dealership so it’s hard to trust. The dealer ship is JD Collins Mornington
  5. Hi all I can’t seem to find the right place on this topic can someone please point me in the right direction or give me some advice. I’m looking at buying a used g6e turbo 2010 50th anniversary edition however it has nearly 200,000kms on the clock, I’ve checked the service history and it seems to have had all regular services up until 165,000kms but hasn’t had anything for the last 30,000kms. It looks like it’s been owned it’s whole life by one owner and he lived in the country in Donald Vic so all those kms would be highway kms I’m assuming. I took it for a test drive the other day and all seemed good there was no clunking from the rear so guessing diff bushes are ok and there was no issues with getting up speed or lurking when changing gears. I guess I’m just about worried that there hasn’t been a service in the last 30,000kms and something is wrong like the dreaded milkshake or even the turbo will require a rebuild can somebody please help
  6. RLord
    Help On 330Rwkw
    ok no worries will ask around then
  7. stage 1 kit sounds good how much for fitting does anyone think it would cost?
  8. RLord
    Help On 330Rwkw
    hey ratter not to bad about the group buy stage 1 kit would be good how much whould it cost to get it installed you reakon?
  9. RLord
    Help On 330Rwkw
    no but will check that out though, still learning my way around the website
  10. Hello guys, been a member for a little bit now and after reading many different forums thought id say hello and try to get some help/info on achieving 300rwkw. I have a fg xr6t ute mk1 2011 build. am very happy with the car just thought or expected more power or that feeling of getting sucked into the back of the seat, so thinking maybe I should do some mods!! so far all ive done is k&n filter and modified the air intake a bit got the idea from seeing dillz hole in his airbox and making my own air scoop out of pvc an idea I sourced from browsing many forums. have been chatting to Simon from Nizpro Melbourne and am thinking of getting the stage 1 plus kit which consists of... 1) custom tuning 2) xcal4 3) hi flow injectors 4) modifying the cat 270Rwkw price $2,995 would like to go stage 2 package but funds are lacking:( just after some help/info on if this is a good package at all or not?
