gbp
3 Neutral
  1. Installed mine behind intercooler, only thing I noticed was cooler trans temps, ZF shifts fine on and off the track - used this one http://www.ebay.com.au/itm/121778714579 Because I have a pretty thick intercooler I removed the aircon radiator (I already broke the line going into it fitting IC so no issues there lol) so fitting was super easy.
  2. got a gauge for the 3 pod on the dash
  3. There is a plug in the side of the ZF as per picture - can it be used for oil temp?
  4. Zf6spd https://drive.google.com/file/d/0B2Bcpb7hKreaQjhsQnFPNEVKdXM/view?usp=docslist_api Sent from my SM-G900F using Tapatalk
  5. Ended up triggering 1 fan with a 30a switch, no relay - does the trick
  6. ok, drag tune sounds like the go cheers
  7. Fans - Anyone Got A Easy Way For Me To Trigger Them Manually As Required They never turn on but would like them on for staging and things like that. BFII XR6 Turbo 315kw at rear
  8. I think mine is the torque converter because it locks in gear and slips during change
  9. Its weird does not slip in gear, I can push it to full boost easily with no slip. It's only on the gear change up or down it slips and if revs are too high *during* that change it goes into a limp mode stuck in whatever gear it happens in.
  10. 150k, box isn't tuned
  11. Hey guys, Started today, first I thought I heard it slip, then after that a weird whine could be heard, parked up and left for 4 hours. Came back seemed OK for the first 5 minutes but then it slipped between gears and then a huge slip, after that it was stuck in 2nd with D flashing. Stopped on side of road and turned car off, started back up and D is no longer flashing and it changes gears but the slip is still there so I have to baby it. Any ideas what I'm in for? OBDII says... PO741 - Powertrain (Yellow) Torque convertor clutch circuit performance or stuck off. PO782 - Powertrain (Yellow) 2-3 Shift PO701 - Powertrain (Grey) Transmission control system range/performance Only slips between gears, I havn't pushed it so it hasn't done the flashing D no changing thing again. Car is tuned to around 312rwkw, trans has been out to tighten flexi bolts but has been down quarter since then. Any ideas? Is it torque converter? Need a rebuild? electronic?
  12. Never thought of that, looks stealth as
  13. Anyone done it? Any hints/tips? Turbo is about to poop itself and I have another aftermarket one here but no wastegate built in. Currently tuned around 312rwkw, 4" downpipe etc.. Thinking about going in here, 50mm... Any issues with this spot?
  14. Drove the car for 3 weeks and on a 500km trip, was so easy to stay off boost, had a gauge so I could take it up the .5 bar without worrying so I was worried about nothing
