eaturbo_39
  1. Turns over fine just not firing
  2. Have you tried brinks performance in townsville their pretty good from what I hear
  3. Hey guys I recently rebuilt my xr6t engine amd everything was great except I forgot timing but worked that out and all good but now I have started it it had a ticking noise like a sticky lifter and was running on 5 cylinders while the head was off I had it checked and all good but removed the rocker cover and inspected them anyway they are all good moving correctly and in time the noise was really loud when I took the throttle body pipe off and ran it but since taking the rocker off and back on again it now wont start no spark please help
  4. Yeah I have timing cover off already and just found the marks lol blind as a bat I must have been. For any one else chasing the info the yellow chain link lines up with a small line on the crank shaft and then the orange one lines up with a mark on the teeth of the crank shaft gear . The cam gears have small dots on them below the teeth with both point straight up and the yellow chain links line up with those at the top
  5. Hey guys newby on this site and I need some assistance upon replacing my head gasket on my xr6t I put the engine to TDC and now its all back together but the timing chain does not match the yellow tags I thought were timing marks has any one got a pic of the timing marks or any info on it please. For it to line up now its 180 degrees out is this right?
