BGBOSS
2 Neutral
About BGBOSS
  • Birthday 23/12/1987
  1. Happy Birthday BGBOSS!
  2. Happy Birthday BGBOSS!
  3. I'd go a oil line filter kit. They're reasonably cheap as is though
  4. Currently retailing at $160. I can recall once upon a time the shift-i's were around $125 on their website. I may be down if the price was right..
  5. Hey guys, Have a bit of an issue and wondering if anybody has come across something similar. It's basically a ticking through the speakers, very similar to the keystroke sound on and ipad/iPhone. I fixed a resistance issue with the sterling wheel controls and the noise disappeared.. I figured that to be the cause. One month later.. I moved the tilt on the steering column this arv, as soon as I moved it the noise returned. Have disconnected the wheel controls, clock spring and given the harness a wiggle all to no avail. Wondering if anyone has come across a similar noise. Can be heard here: http://youtu.be/TD7yhjDW2Ek Sent from my iPad using Tapatalk
  6. From the pics I've seen, it's not quite a 90 degree bend.. but it is after all just a bend. If someone could figure out the bend angle and tube length that's half the job done
  7. +1 for the delete pipe. Steep is an understatement
  8. +1 for genuine. I had the same drama
  9. Plasti-dipped the chrome ring around the ford badge for more of a subtle look. The edge appears a little rough in the pic but it's clean in the flesh
  10. Was Just thinking. Correct me if I'm wrong but the factory premium setup has the signal sent to the factory tweeters directly out of the icc. Wouldn't that mean adding aftermarket cross overs using the speaker wire as a source be using a signal that already has a lot of the high end filtered out of it? If all your doing is replacing the speakers, wouldn't you be better off fitting aftermarket speakers and tweeters to the existing wiring?
  11. ^ Mines 09 and it's enabled in icc settings
  12. G'day all. Newbie here. I picked up an 09 XR6T today. It's got leather, premium sound and from what I understand, factory sat nav with a remote. When I push buttons on the remote. The unit in the dash beeps but I get nothing on the screen. When I push the speak button on the remote, the system tells me the name of the next upcoming street telling me the nav system is working to some extent, however the visual side of things does not seem to be working. Is there something stupid I have missed??
