quadie
Everything posted by quadie
  1. Rhino f6 broke the chainsaw turbo powered ass *beep* already ! He's an animal! Time for a 12" *beep* this time,
  2. Yes www.aslautomedia.com.a
  3. ali does top work , 2 things to take note of with ali his dyno is know to give low readings( also dyno numbers are worth piss all , go by MPH , that's a better indicator of power) ali also tunes for torque , power is a byproduct, if your not happy ring him and chat to him! look at the trend of his dyno figures, most have average Power but great torque figues mine for example 326kw , seems low , but at 1190Nm , it beats a 350Kw car all day
  4. Then I recommend an eliminator
  5. Riddle me this feirce. What your total current draw when off for longer that 1 hr. to allow for energy saver mode to kick in Whats the current draw of the alarm system when armed. I suspect its the alarm that's the drain. Do u park your car for long periords that causes the drain ? If so id reccomend that you Set up a battery eliminator ( trickle charger) With a plug discreetly mounted somewhere ( like inside a wheel arch. Or trailer plug if u have a tow bar.
  6. cheap audiocontrol lc6i but way better than any 50 buck convertor expensive and want topnotch ausionson bit.1 , alpine pxa-660(have on for slae cheap) I have done alot of testing on these
  7. Hey guys I drsperatly need. 2.75 to 3 inch silicone joiner if some has one ring me. I ordered one but the had labeled it wrong and Its 2.75 to 3.5. Idiots 0406 603 351
  8. 1.depend on why the old one died, but most cases yes ( a little) 2. not enough 3. if your gunna get it tuned , do I few cheap things be4 the tune to get better $$ valuve for your tune. Hii-flow aif fiter/ f6 snork or growler, maybe a UBP , monza cool all items are pretty cheap and easy to fit. ali is a top bloke and does a great job. (explains y hes so busy!)
  9. sig update
  10. anything under 90Lbs seated and replace with atomic 90Lbs
  11. yes yes bang bang bang bang bang would work , but im too lazy to take off the rocker cover
  12. plaz +1
  13. whats the firing order
  14. 16th of this month
  15. .7 covered 3582r with wastgate mods. 4" plazmaman air box. Larger hotside piping. Limit will be what the btr tranny will take be4 crying. Retune booked. With bta. Only because of running close to the limit of the tranny. Ali built the tranny. Im sure the car will pull a bigger number than the trans will like
  16. If your on. Does that mean ryan f6 will be as well ?
  17. turbo ordered , airobox ordered , next sat is the swap over day
  18. I want to get mine going again so I can wipe rynoF6!! hehehe
  19. .7 cover is with bigger wheel! ordering tomorrow
  20. yeh either a gtx3582R or a .7 covered 3540 , or the precision turbo , still not sure which way , either way , I want to try and retain the factory look
  21. I thinking something loose in the engine bay fusebox due to range of faults
  22. hairspray readnose! , the mount prob contributed to the pipe off as the motor would have been moving alot more motor got its replacement Valvespings (6 EXH was at 45 seated , others 90), now I got 120 seated! still deciding on turbo
  23. Rhino that's no probs. Come round and help me pull it off and its yrs
  24. due to the stock pump not having to make rail pressure . the stock one is fine and its only filling the surge tank ( low pressure) if you feel you need an upgrade , whack a walbro pump in there ( I have one only due to running it be4 I got the surgy) ebay has a drop in replacement for <$300
  25. well his post was a little vague , so I felt I had to "probe him out of his shell in other news: motor seems ok ,had a weaked exhaust valve spring new set to be ordered turbo screwed, still looking for replacement idea but have found a deal on a .7 covered ported turbos with on 7ks (yes 3 less than 10Km or 7000meter) with all associated fitting parts for a good price so might go down that route. rhino , u buy me anchorlox n gaskets and my old turbo is yours. ill even help u fit it up when u help me fit mine
