quadie
Everything posted by quadie
  1. yeh, I ended up tuning it in my mates spray booth late one night so there was no external noises , even a car going past will upset the tune in it , but the end result was great ,
  2. hows the h660 going spook? for limited space installs , there are a few options. I reccomend the doing the following. goto JB(or car audio shop) with your fav cd , (NOT IPOD) , listen to every set of 5x7s or 6" they have on the wall , let you ear be your guide. decide if u want intergration or a seprate HU for intergartion. Cheap audiocontrol lc6i medium pxe- h660 money no object audison bit1 aftermarket any good (not cheap as) HU that has the features u want audiopro make a tissuebox mounting kit ok so now we have full range speakers and sound input next is amps amps. cheap , jaycar 5 ch will do a good job and be compact best would be a 4ch and a monoblock for the sub sub. again listed to the subs on the wall with the speakers you selected , got for a 12 inch for the following reason. there are a company that does fibreglass sub boxes for the falcons. choice of mounting (all taking up little space) lhs or rhs side of the boot ( I run these) in the floor of the boot (raises the level of the sunken floor up a bit (need to protect sub if chucking stuff over it.) agaist the back wall in single or duel sub these can be removealble easly if the space is needed if u get one of these I recommend chucking some more f/glass inside to stiffen it a bit more so that should get you moving to make it cheaper , do it yourself its not hard at all , and we are here to help I run the audiocontrol dql 8 sound processor fusion 6.5 splits up front with tweeters in stock locations rear are 5x7s also fusion twin 12" powerplants 2x 2ch fusion amp 1x 3000w mono factory icc with dvd kit
  3. Grr
  4. Took it out on sat and washed it. Has given me my drive back to get off my ass n get it tuned. Now need the nearly 10g in child support owed to us and I'll be sweet
  5. ill swap u my cat , got 2 to choose from , ones a fat lazy fluffy one that keeps ya feet warm in bed and that about it. the other is a 5in body cat that's HHHIIIIGGGHHHHHHH flowing , why u want a stock one?
  6. ^^^ 2nd this , couldnt find to reason to be down over 50Kw , on the way home after the dyno check turbo died , new turbo , and wheelspin city !
  7. relay sounding , is the car tuned? my solinoid clicks with one of my tunes
  8. flash to stock with xcal, try a new battery
  9. go loost at stock turbo in a car yard and take pics will require map sensor and other bits and peices it will start but wont last long as the turbo injectors flow more try: http://www.lmgtfy.com/?q=converting+ba+na+to+turbo
  10. WTF???? please tell me your under the influences of a controlled substance
  11. Motec FTW!!!!! we run full motec fun in the boat and I love it , easy to use , so many things u can do with it without needs bunches of other hardware boats are one of the harshest evrironments for this gear , we have drowned the boat a few times and no problems yet!
  12. cut of cig plug , solder to wires on exisiting cig socket ,
  13. do we have a rhys out of cardiff here
  14. bbq at ryno F6 , place
  15. quadie
    Xr6T Xf Falcon
    tolds ya!
  16. id have them , they are power only
  17. big brother ninja?
  18. quadie
    Xr6T Xf Falcon
    stall it and punch that puppy into a 9 *drool*
  19. the one he started 27 mins eariler wooahhh I sound like a mod!
  20. take the driveshaft out! , if the they mange to start it after putting the wheels back on , refitting coils and and any other plugs u undo , plus refitting batt. that SHOULD keep them busy till the cops arrive
  21. well done dosey , cheers to ali again!
  22. DONT MINE UP OLD THREADS!
  23. so far , nope HVAC needs to be cracked
  24. quadie
    No Boost
    Diff bush
