quadie
Everything posted by quadie
  1. my footwells have been blue for years , im married and dont get laid , maybe I should put red ones in?
  2. Haven't played with the 800 yet but looks the good Behind the fuse panel on the drivers side there will be a blue 4 pin Connector if it has a connector in it its most Lkely for the boosted input. There also is a 5 pin white plug. This is where the aux audio input plugs in. Trace it back over to the plug under the tissue box. If there is a black box it's Boosted. If its straight through its not. Box is usually between the ICC and the steering wheel Hope that helps
  3. Don't forget to reset the 650 and redo the setup procedure as it will now have full range
  4. I had the same problem when I put my lc6i in. And now it's just like an aftermarket head unit. I'll swap you my lc6i if ya can't get it sorted
  5. That is why I asked if you had premo sound. DISCONNECT your factory amp on the left hand side of your boot. Then switch ign off and back on. When the ICC see the amp on the canbus it enables high pass filters on the rest of the system. This is why you have lost low end response.
  6. im sure that these measurements have been done be4 in the wheels and tyres section. I will be putting my brembos on this weekend if all goes to plan and will do measurements then I have 6pot fronts and they have less clearance than the 4 pot fronts.
  7. They are a nice bit of gear the miller rigs. Will give you many years of great service
  8. 4 pots run the same 355mm rotor. as the 6 pots
  9. Spot on. It's going to sleep after timeout
  10. Did you have premo sound (with sub) pre fitting sound processor or any audio upgrades? Sound dreading is super necessary in the doors on the back shelf and boot areas Especially when going for sq
  11. hey feirce , what tig u getting ? I got a transtig 200
  12. at the ford forums , no1 has found a 17 inch rim that will clear 4 or 6 pot bembos , the minimum is 18" even then the range is not so great!
  13. well done mitch!!! good to see its still together.
  14. Iphonrs users : u need an app call REV and the ebay dongle to get is called KiwiWiFi (its a wifi based dongle as the iphone has a poor bluetooth connectivity, or you can use the ELM 327 based bluetooth, but require a jailbroken iphone and a bluetooth stacker app
  15. woo , the pic just loaded for me!!!
  16. no probs!, I would suspect tht drop of oil would be related , while your in that area , grab a can of nulon carby cleaner and an old toothbrush and give the throttle body a clean out , your engine will thank you for it.
  17. as technology get more and more "computerized" we have to remember that a computers aint perfect and can fault from time to time I work in an industry that is more and more computerized rather than bunchs of componants. I use computers more to diagnoise and repair rather than my DMM and CRO
  18. PCV , Positive crankcase ventilation. this device vents excess gasses that build up in your crankcase from blow by and rotational forces. releasing the vapour into the inlet to get burnt during the combustion process with it out of the inlet , it wont hurt other than leave a small film of oil in the surrounding area
  19. PCV valve
  20. 300 + shipping , bendix pads (30%) and dba slotted rotors (30%) I have brembos to go on mine
  21. I bolted my FPV premo calipers to the exisiting mounts when I went from XR6 turbo stock to the FPV/PBR 325mm? calipers and rotors. these are up for sale at the moment these are the blue FPV version. comes with rotors to suit
  22. pull the BATT off for 1/2 an hour and reconnect to reset the ICC , sounds like it gone loopy,
  23. behind the fuse panel on the drivers side you will find a blue 4 pin connector , thease have B+,acc,earth,phone tigger for ICC. also you will find a white 2 pin connector , this is the audio in of the phone side of the ICC I cant remember the wire colours off my head right now but I can hunt them down if you need them. only issue is the input to the ICC is a mono channel. not sure what output that model of parrot BT has. if it has AD2P , you could feed the AD2P audio into the AUx input when your listening to music via the parrot. when a call is received , it will activate the ICC into "media" mode which is the phone input. let me know what connections the parrot has and ill let you know what needs to be connected to what. the connectors behind the fuse panel will accept a standard male spade terminal
  24. must have mid level harness (good Icc) or above from memory. povo packs , pull holders out or parkers at the wreakers , taped to the the Cig Lighter socket is a lamp holder tap of this to feed power to globes. those pics look pretty close to my BA (premo sound).
  25. replace the Diode in the boot light , that will cause the the alarm to trip for voltage drop when the BEM goes into sleep mode about 15 mins from memory . the diode stops this (YES it was a big pain trying to work out why my alarm would go off for no reason, of cause the neighbours didnt like me a few weeks)
