ugy
Everything posted by ugy
  1. ugy
    Better 60'
    Heatsoak. As my general rule of thumb goes, you first run will be the quickest, and have the best terminal speed. I have gone against this once, when I was learning how to drive the ute at the strip, bad launches and wheelspin aside of course.. . And yes, trap speed is the average speed between 2 light beams at the end of the track, so keep on the gas for a sec or 2 after the line.. ← Certainly looks like heat soak I did three runs 1st...60'- 2.345 1/4-13.095 MPH-114.72 2nd...60'-2.336 1/4-13.094 MPH-113.72 3rd...60'-2.404 1/4-13.143 MPH-114.44 Between 1st and 2nd runs was a gap of 1/2 an hour I done the 3rd run straight after the 2nd. No wheel spin on any of the runs.
  2. ugy
    Better 60'
    Thanks for that. I was trying to work out my rear wheel kw. At the moment I am doing a 2.400 60' and 114mph (without stalling it up) so I would expect a little bit more mph at the other end if I was to stall it up.
  3. ugy
    Better 60'
    Hi, was wondering if somebody could tell me if the lower your 60' time was. The better your MPH at the other end Thanks in advance
  4. Try shifting your back tyres on to the front and see what happens. just a thought it could be a tryre
  5. ugy
    V8 To 6turbo
    If you are going to drag it seriously,get an auto
  6. ugy
    V8 To 6turbo
    About time you turned the light switch on
  7. Hi, was wondering if someone could tell me the maximum power you can get out of the factory Catm Thanks, Bill.
  8. ugy
    Passing Of 05
    A GREAT MAN AND A GREAT DRIVER. RIP PETER BROCK
  9. When I gutted mine I went from 285rwkw to 320rwkw I kid you not. But in saying I would like to change it to a hi flow cat if I could get the same increase in power.Also gutting the cat makes it quite a bit noisier.
  10. Not trying to rain on anybodys parade. Wondering what would happen with your insurance company if you were shunted up the ass and you caught fire.It is a great setup and if the price was right I would buy one but I would check with the insurance co first for peace of mind.
  11. ugy
    Little Bingle...
    Dont look like the airbags went off either. I would have thought even without a direct headon it was still a bad angle and at least the front bags should have gone off.
  12. Mines a 2005 MK11 Shockwave and is the same as yours.Looks good to
  13. I got 280rwkw with the factory cat so that wont be the problem.
  14. ugy
    Gapping Plugs
    I have done 15,000ks The more times I went down the track the better the car ran and the better times I got,which seems strange.
  15. ugy
    Gapping Plugs
    Thanks Ian, yeah .89 of a mil... LOL. I have had the springs done.Just that the last time I took it down the 1/4 on one run it was missing all the way down the run,not all the time just intermittenly and I thought the plug gap could be an issue. Bill
  16. ugy
    Gapping Plugs
    SORRY.....I know this topic has been done to death a few times. I have surfed the site and checked the threads but am still none the wiser on what would be the best regap for my plugs. At the moment I have 14psi and have regapped the plugs to 89. I have two questions. 1... What is the symptom of to bigger gap 2... What would be the best gap for 14psi Thanks
  17. I agree
  18. I had trouble with mine once they start turning they are normally stuffed. What I did was get a drill bit the same size and drill them out and refit new ones.
  19. Looks like the lights and tow bar gotta go
  20. Put mine on front and rear the handling is so much better.Been around some tight corners and the rear seems to be ok. Find the car seems to be a lot stiffer.No dissapointment here. So easy to put on your self.One thing I did notice is my passenger side bar hanger (I think that's what you call them) was slightly bent and they look pretty flimsy to me. Wondering if you can get stronger ones.
  21. I know what you mean. You either luvem or hatem
  22. Hi Jordak it has ben dropped but a set of M/Ts are coming before the rims
  23. Back and front
  24. I have asked everyone that have seen it what they think and they all said they like it so decided to post it on the forum to see if they were just being kind. overall the feedback has been fairly good and I must admit it does turn heads. I will post a bum shot for the fetish freaks
  25. Yea silver on black would look good. Didn't want to put white stripes on and thought wider stripes would look a bit overdone.
