ugy
1 Neutral
About ugy
Contact Methods
  • Website URL
    http://
  • ICQ
    0
    Auckland
  1. ugy
    Btr Gearbox
    Still rather pay the service costs than the repair bill. Mines on the way out for the second time. Was going to check the fluid level hoping that it's low fluid,some how I don't think so
  2. ugy
    Btr Gearbox
    Thanks for that
  3. Hi,could someone tell me how to check the fluid level in the 4sp BTR Thanks,Bill
  4. I would say your warranty would be ok unless something went wrong with your car that the K&N could have contributed to, then I suppose they would try and get out off it. As for power I did the same times down the 1/4 with my K&N and my factory filter. But hey the sucky moto sounds better.
  5. Great write up thanks for sharing.Sounds like you like your FG as much as I like my BA2. Cheers
  6. ugy
    Stallie
    Hi guys, I am in NZ and was wondering if anyone knows what the Jim Mock one is like and do I need to swap mine with theirs. Cheers
  7. ugy
    Vibration
    I had a new exhaust put on and the gearbox recoed about the same time. The flex plate could be the problem or I heard that the torque converter can vibrate and sometimes needs to be shifted around one hole.
  8. ugy
    Vibration
    It's an auto. I have a pit in the garage and have been under the car when it was idling and had my hand on the engine cross member and gearbox cross member and no vibration on them at all. Soon as I put my hand on the engine I can feel a vibration which transfers to the body of the car. I would think if it was a busted mount on the engine or gear box you would feel it through the cross member. Also there is no rattle or noise just a vibration.
  9. ugy
    Vibration
    Hi guys, I have an annoying vibration when I am idling, but as soon as I rev the engine it goes away. I also have the same problem when I am cruising but as soon as I accelerate over the 100ks on a private road it goes away also. I am leaning towards the exhaust but have had a look underneath and can't see it hitting anywhere. Would appreciate any suggestions on what it may be so I can check it out. Cheers Bill
  10. Have you had the car lowered? I have the same problem and I have lowered mine and heard when your car is lowered it can cause vibrations.
  11. Don't worry until it start's thumping between gear changes. It could be anything
  12. Does it do it when the oil is cold.? Mine done the same thing when I took it around the track and over heated it.When it cooled down went back to normal, but 6 months later new gearbox.
  13. ugy
    344.2 Kw. Yay!
    Scuse my ignorance guys,but are the green tops 968s Cheers
  14. Mine is doing the same only I have it when it is idling as well. Bought a set of coli packs on Ebay so will try them when they arrive.Also when I rev the car (in park) to say around 1500-2000 revs it has an intermitant (spelling) miss Will let you know how I get on.
  15. Mine had the exact same symptoms. Eventually went into limp mode and that was it. New gearbox
