griffith
  1. Thanks, I looked through the whole thread and I couldn't find anything regards to the Boost Adjustment settings when you edit your vehicles profile. I added and I am using the Ford PID It's in the options under 'Current Fuel Level' and it says: Boost adjustment (usually -14.7, 0 or 14.7 (atmospheric pressure adjustment at sea level). I left it as 0 but it seems to be reading a bit high, what have others used?
  2. Anyone know what number to put in the settings for the boost adjustment so the gauge reads right
  3. Bummer about the diff bushes, I had mine replaced the other month as I found there was excessive backlash when accelerating and then backing off. While they were there they found the diff cover leaking, so they popped that off, replaced the gasket goo and added new fluid. Was all covered under warranty fortunately
