Ralph Wiggum
Lifetime Members
    310
  1. If you're buying and modding a mass produced non exotic for anything other than the enjoyment of owning/driving it your playing the wrong game.
  2. I had my darling wife 99.99% sold on the idea of buying it. Makes total sense that now I've got two sons Im going to need two F6's to hand down right......? But is sold be the time the last .01% was properly justified.
  3. E85 for shizzel ma nizzle kyldizzel.
  4. Less talk more E85.
  5. /r/midgetfurryamputees?
  6. Same same it'll still draw the oil out.
  7. The brazing used to fix the fitting to core will be slighlty porous so you've probably washed the oil from the cap out of the pores. If your worried its leaking I'll take it off your hands.
  8. Intake can has the notch closer to that rear timing teeth. Exhaus its closer to the last cylinder lobes
  9. FG rails aren't stainless either.
  10. BA/BF fuel rails are exactly the same. Neither are stainless they are electro plated steel. Also are you aware of the full requirements to swap a ZF6 speed into a BA?
  11. But it polarises! FACT! (FACT! need to be in CAPS)
  12. Is your polariser plugged in backwards Keith. Also starter motor does generate current when cranking. But it doesn't get out of the Starter.
  13. Well I think we have successfully derailed this thread, I'll be on my way.
  14. I don't work FIFO anymore and I daily a Range Rover (NB said range rover is worth less than 4 new gram lights and a gtx357r) Stripes SRS question, what is the FIFO exist strategy for a rock licker? Project Feasibility studies Perth based etc?
  15. Only if you are using metallic pads. If your using ceramic pads they will insulate the system.
  16. Only if you crank while rolling backwards over the third rail.
  17. TIL back emf charges while cranking.
  18. There's a fine line between overly cautious and paranoid.
  19. They are discontinued. Most dealers will give you a blank look if you ask for the part as it appears to be a single spec (FPV) one or two model year part. I used two 3/4 to 5/8 (19 top 16mm) brass barbed 90's to replace the cooler I'm sure you've probably seen my thread but below is the parts diagram from Ford. there are some pic of how my setup ended up. NB: at the time I was running the PWR trans cooler.
  20. *velocity
  21. Who are we appointing to Text Double R Ron so he doesn't feel left out?
  22. Hmmm might have to gtx myself for this one.
