Ralph Wiggum
Lifetime Members
    310
  1. I've had one of there dumps for about 5 years. Good item for the price
  2. ^this guy
  3. Anyone else remember when dillz was pro ZF to the point it was painful. Then his ZF shit the tin, then he was all pro t56/tr6060 and he copped so much shit he rage quit? Good times.
  4. He won't have access to the repository rolls. Mike I'll email you some tonight.
  5. Fuck this makes me giggle everytime you post it.
  6. I was being facetious mate. I don't believe you will be able to prevent the over boost with a preload adjustment. Especially given the exhaust has been changed.
  7. Would you class that as a personal attack?
  8. Did you try extending your rod?
  9. Needs chunks of apple in the pancakes for true canuck breakfast but I'm with you either way.
  10. @pj4000 What's the alignment like on the actuator rod? I've found the ts iwgs need the bracket tweaked to correct the alignment. They have a nylon guide bush in the bottom that doesn't like too much misalignment and will cause additional drag on the rod.
  11. I don't see any personal attacks from my side? I've just asked you a couple of questions? I interested to know because perhaps I am wrong but I can't make that call without you clarifying what you believe is Incorrect about what I posted?
  12. Who's upset? I just asked a couple of questions and asked how you would deal with a particular scenario to better understand your knowledge and experience level?
  13. What is incorrect about my information? I'm also interested to know how many of these cars you've setup and tuned with a ts iwg especially a b series car with a stock wastegate. Im also interested to know how simply adjust preload will help with a car that overboosts at peak ve then drops off up top?
  14. *.jif
  15. LOL. If you think that is provocation......you need to get outside more. Try being the bigger man and not responding. It'll put hair on your hamsternads.
  16. *chews them. Like a hamster
  17. Turboknapp ordered mine and his at the same time from a seller on ebay. I think we either paid $180ea or it may have been $220. Either way it was back when the USD was a touch less healthy.
  18. I've had a couple of TE units in the past and rate them. I've got an MTX-l in my car and an LM2. I replaced my old tech edge with the LM2 as the logging capabilty is more user friendly. Edit-MTX-l is fine to cut your teeth. Good for P98 and E85 and can be logged by the MVPI.
  19. Yeah he got me on that one. Not as good as the Safety Step got me but not bad either. I'll get you next time stripes....next time!
  20. Get the Pro version for the additional inputs for logging. You'll also need to budget for a wideband afr meter/gauge. Opinions vary but most of the name brand units are pretty good.
  21. Bummer, Matt didn't post the shipping docket with your details so I didn't get a chance to edit the photo with a drawing of a big wang to hide the details.
  22. Mike, HPT have a demo version of the software on the website. Maybe grab that and have a play? I've got a couple of FG Turbo files I can send you so you can have a look if you like. You can learn a lot from looking at the various models and the changes ford made to the calibrations
  23. The issue with reducing preload to prevent overboost on a stock port size is reduced response and high rpm blow out. Ideally you want the wastegate closed as long as possible to maximise the drive pressure on the turbine (for response) and then you need the port to flow enough in the midrange to prevent overboost, but still enough control (from a decent spring rate) to prevent the gate blowing open up top. If you have any post or pre turbo aiflow mods and want to use your TS IWG you'll at minimum need to get the tune adjusted to suit and potentailly you will need the port job. FWIW I really like they TS actuators. They need slightly different approach to set up and tune than a stock garett unit but IMHO the higher mass of the internals helps improve spool up and give a smoother curve (assuming mech conditions are correct to support this)
  24. 5/7 on the roller blade scale?
