Ralph Wiggum
Lifetime Members
    310
  1. No it's not, but if the wastegate is capable of flowing enough to control the boost pressure, plumbing the actuator directly to the boost source will control boost just fine, at the expense of response and possibly boost up top.
  2. You don't need to go ex gate although it would give you the best control. A simple wastegate port job and larger flapper would also be suffcient.
  3. Yes, changing to a high flow cat without supporting boost control mods (ie wastegate porting) But a blocked cat will cause an exhaust restriction that will hurt boost.
  4. Blocked cat will cause loss of boost not over boost.
  5. There ironing of pointing out shitposting with a shit post. Have you met Steve? kinda creepy doesn't even come close.
  6. Get the wastegate ported and car tuned properly.
  7. which Guy? Me?
  8. LOL that would have been funny.
  9. I don't understand what you mean?
  10. Duuuuuude server space.......server space FFS
  12. Yeah I have a probe but don't bother using it for steaks etc. I don't used the dome Temp gauge as it's proven itself to be fairly inaccurate. I'll give the deflector plate ago. Wifey is keen to do a chunk of pig for pulled pork dishes so don't want to cremate it. Thanks for the tips!
  13. Just the top and bottom vents and charcoal placement to control temp. Mine drops intially but then roars up once the lid is closed. I cooked some steak on it last night and used a handful for charcoal and it still does it.
  14. This gets me all the time. Mine rises slowly and tricks you into thinking it's stabilised then will spike once you put the food in. I think the time it's open must draw enough draft to get the charcoal all stirred up.
  15. Dank before Dank was Dank.
  16. Keep that up and you'll be knock ,knock,knocking on heavens door.
  17. I was hoping we could throw together a multiuser sing along but you've ruined it Rab. I hope you're proud of yourself.
  18. I can fly.
  19. I want to believe.
  20. And then? Keen for specs on weight/temp/cooking time. I'd like to give this a go myself.
  21. That picture actually features another well known WA Member. Those who know who it is keep it quiet. Those who don't are free to try and work it out. Let me just say he might be a tad touchi about my posting it....
  22. Got milk?
  23. Those figures are normal. Tmap reads absolute pressure so atmo is around 14.68 psi and boost is atmo plus boost pressure so in your case 15 to 16 psi boost plus atmo = 31ish at full load.
  24. Good Chat
