Ralph Wiggum
Lifetime Members
    310
  1. LOL I was just discussing this with Wife via text and she couldn't wrap her head around a boat cruise to Pemberton.... No dear it's a car cruise....
  2. Sadface, I spose there's no reason I couldn't spend two weekends down there.... Any WA peeps got a use for a webber BBQ? Got one spare going begging. It won't win any beauty pageants but it cooks meat good.
  3. next weekened? as in the 20th? or this weekened coming? Turboknapp and I (and Fam's) will be down there the 20th.
  4. You've always been the dankest member I know sweetcheeks.
  5. You've changed. You used to be cool. It'll rattle like the bf in no time.
  6. Awesome, Thanks for the info. Too bad it doesn't work. Good Chat.
  7. Where are you located?
  8. Awesome, Thanks for the info. Too bad it doesn't work. Good Chat.
  9. Sorry Steve, we've got another primary Steve now so you'll have to find another forum.
  10. She's from Adelaide. There IS definitely a least one set thongs/trackies in there somewhere.
  11. Earth on the battery.
  12. Pics? Bosch injectors don't come in retail packaging so quite likely they would be reboxed. http://www.raceworks.com.au/fuel/injectors/bosch-2200cc-short-denso-plug-injector/ "Bosch" Injectors covers a fairly broad spectrum. Bit like saying "Ford" Car. Ford make plenty of cars but some are better than others.
  13. $40/kw up to 400rwkw then budget $80/kw after that.
  14. For an FG Short install, budget for the motor $3.1K + freight (3.1K was landed in Perth so if they are able to do ex melb it may be cheaper, but knowing my parts guy he would arrange it to be transported on a stock transfer) Top end Gasket Kit (head gasket/rocker cover gaskets/seals/intake exhaust gasket) $500 Sump U seals and Sealant $50 Fluids?? Depends on choice/preference $150 to $ 250 As for the head stud bolt/stud option. If your plans are to max a stock turbo on P98 use Gen Stock Bolts. If you have E85 plans it's worth installing studs. Note you cannot reuse to original bolts Im assuming your cylinder head is in good nick and doesn't require any work otherwise that'll quickly swallow 1k
  15. well consumables such as headbolts v headstuds would be determined by final power goals.
  16. How long is a piece of string? Depends on what you want to achieve Power wise.
  17. I can arrange the purchase if you can arrange frieght.
  18. Which rear calipers do you have? 42108's are for Brembo calipers 4507a/b are for PBR calipers
  19. that's a good price considering braided hose and fittings etc included. If I was paying retail for parts I doubt I'd be able to get it any cheaper.
  20. Personally I buy the cooler and fittings and spec my own hose. I've done 3 of the Mega cools (inc my own car) and all up it'll run you 5 to 6 hundred by the time it's installed but I don't think you can go past it for the combo of size/quality/performance.
  21. Generally not suitable for turbos due to clearance issues with the rad/intercooler. Non of the off the shelf kits will give you enough hose for a behind the fog light mount.
  22. Yeah they lefts over fittings where just 4 x 90deg -10 elbows and the an adaptors for the trans cooler ports. In reality you'd only need the adaptors and 2 x 90deg - 10's
