Ralph Wiggum
Lifetime Members
    310
  1. Gotta have that big big big number. Don't worry about the area under the curve.
  2. Im highly skilled at spending other peoples money!
  3. where are you located? Im running the gtx3576r/E85/ZF?Sticky tire combo and it's awesome. Still blows me away everytime I drive it.
  4. My boss told me in my last performance review "when you hit a roadblock I want to you make sure you do all you can do before moving on to the next task" hit a road block with getting a PO approved and boss is dragging his heels approving it. So I did all I can do and went over his head to his boss, no luck. So did even more all I could do and went to my bosses bosses boss(my previous direct manager) to get the PO approved so the work can continue. Now have my boss ringing me pissed off that I went over his head. "I did all I could do" was apparently not the right answer. Also this popped up in the racewars whatsapp shit talk chat and was too good to leave there...... the topic of convo was sum up your day in one pic- and me
  5. PC925 it will be a tight fit. Any smaller and the battery will be far too small
  6. ^whs Lash adjusters should be okay, but you'll need to change the followers.
  7. They are most definitely not the same. BF2 did not get duo phased cams are per FG and niether did the lpg engines. Ford have probably discontinued the BF/LPG cam Part Number hence one size now fits all. They did the same thing with the engine/trans cooler piping in the b series cars. BF2 non thermostat no oil cooler piping was the same part number as the BF1/FPV setup with the trans thermostat and engine oil cooler. The piping in reality was vastly different. If I was you I'd talk to Brad at atomic and see what he can do cam wise.
  8. Someone woke up on the feisty side of the bed this morning
  9. ^ 5/7 Rebuttal. Should have picked on the under cutting on the Welds for the top hoses and the tarnish from lack of Polish.
  10. What's happening with the pte?
  11. Pump to elbow hose is too long. Assembly not square,hose clamps not aligned. 5/7wnb
  12. It's a breather pipe. It doesn't connect to anything. It should have a small filter on the end to stop debris getting in it.
  13. You shoulda bought ongates or baxrutes old motors. You can see inside them without pulling them apart.
  14. Got a multimeter? Measure the resistance across the pins. 4 will have resistance that changes when you move the tb two will stay constant.
  15. Sheet 14 in the wiring diagram doc. 303-04c Single Fuel LPG.pdf BF Wiring Diagrams complete (1).pdf
  16. Something something less time for murder something something Congrats bcb agree 100pc
