Ralph Wiggum
Lifetime Members
    310
  1. Good luck finding rebuild parts for GT series turbo's. Garrett stopped supporting them prior to the release of Gen1 GTX's and have now done the same with the Gen1 GTX post Gen2 release. A good secondhand GT3582 or a china CHRA (depending on what you intend to do with the car longer term) are probably you most cost effective options.
  2. Do you even lubricate your turbo bro
  3. Protective tubing at rub points ain't a bad idea.
  4. USB boroacope,cheap as chips online jam that down the spark plug hole before condemning the motor.
  5. It's hard to loosen 80ftlbs when you only wiegh 75lbs
  6. Who's fiddly t and why in the dining/family area.?
  7. Not hard to guess who's post it is when there's only half a dozen people posting.
  8. Ralph Wiggum
    Help!?
    What headunit are you using? You say you wired the speakers directly to the headunit? have you disturbed the plug for the headunit harness when installing it?
  9. ^WHS
  10. Ralph Wiggum
    Help!?
    If the headunit is powering up but not delivering sound why would you check fuses? Clearly it's getting power. More likely you've accidentally muted the unit or selected preouts instead of internal amp when fiddling around putting it back in.
  11. Ralph Wiggum
    Help!?
    How did you wire the speakers? directly to the HU or through an Amp?
  12. I haz a guard roller.
  13. Smash a socket on it.
  14. Socket Smash is the way to go. Once you so how easy it is to remove them you'll realise how pointless the stock locknuts are.
  15. I hope Prince Phillip hasn't kicked it, his 19th Century Non PC ways are a hoot at times.
  16. What's he going to do? Swim back from Malayshanesia and stop us?
  17. I'll have a black FG F6 Ute most of the weekend. Lets make a deal.
  18. Have you tried turning it off and back on again?
  19. "I like her for her music" AKA "I read playboy for the Articles"
  20. Brett, I run PMU HC800+ fronts and NS400 rears in the F6. Have been dailying it the last few days and the initial bite from the HC800's is excellent. You can't tell they are a street/track pad until you lean on the pedal and it throws you through the windscreen.
  21. I usually have a couple of shots of e85 first to calm the shakes.
