Ralph Wiggum
Lifetime Members
    310
  1. Not really like, more likely better than xcal for the average Joe as it can be permanently installed in the car and used as a functional gauge and (to the best of my knowledge) the ngauge isn't vin locked so could be used to support multiple vehicles, each car would need it's own licensed tune file obviously.
  2. Yaw sensor is located on the steering column
  3. Your injectors and pump are miles to small for e85
  4. that's wagon is a pos and the owners a jerk when hes been drinking
  5. ^ http://www.news.com.au/lifestyle/health/health-problems/skinny-fat-why-its-more-dangerous-than-you-think/news-story/33b1ebd8a817ec0e3e549890773afda8
  6. Looks like someone has already eaten it.
  7. You want hectic whistle? dodis You've heard of the legendary "Batmo" mod that was done to comp wheels back in the day? We are bringing it back with our new "Shatmo" mod.
  8. Wastegate Actuator is designed to only receive a pressure signal, vacuum at cruise will kill it over time.
  9. Your plan is fine. If/when you plan to up the boost don't use boost T get a decent boost controller (eboost street or eboost 2 for example) they can be had for a couple of hundred bucks secondhand and will work perfectly with your intended setup. Turbo Tmap is not a straight plug in, the pin out is slightly different so you will need to change that. The pinouts are readily avaliable on the WWW. Don't bother with turbo pcm/loom/etc add significant cost for no real benefit in a conversion such as this.
  10. Where did you tap into the factory speaker wiring?
  11. Anyone dropped a Cornwall reference yet?
  12. Because if you are only packing 8" every .5" inch counts
  13. Yeah I posted that. And forum doesnt like n a z I s apparently
  14. I thought you don't sleep? You're a perfect candidate for kids.
  15. I did, but just so I could see the hoses and drop it out the bottom.
  16. Nothing, but did spend some time on this- (owners Id has been obscured to protect the innocent) Also...
  17. where are you located?
  18. how gold is gold?
  19. FCA and the Average build quality of Jeeps is the perfect storm of sh*t experience for the consumer. Avoid
  20. They will be seized worse than the ones off the red car
  21. LOLWUT COV's for me where sub $200 for the standard PBR Twin pot Front
  22. Kthirtyoneth, Get a price on new replacement calipers from whatever the equivalent of Repco/Coventries on your side of the world. Last time I priced reman a calipers vs brand new units there was SFA in it price wise.
  23. What are the specs on the housing? Your options are likely fairly limited unless you're willing to get the housing machined.
