Ralph Wiggum
Lifetime Members
    308
  1. Blew the r sole out of my old faithful Alpine 12" sub today. Not really pissed off that it died as it was 10+ yrs old so didn't owe me much. Pissed off because of the smell. Burnt epoxy anybody?
  2. Previous owners a dick and all the work previously done to that car is shonkier than a free SA dyno tune. Brad, I'll be acting as chief motivator on this one so it won't be stationary for long.
  3. What do you do for a windscreen washer bottle with that cooler setup?
  4. Bunnings, 5 x quick set concrete bags.
  5. Nope. Your seeing those codes due to the auto tune being installed in the PCM. Jump on the hpt forum and put the call out. You might find somebody who'll come and edit the tune to suit the manual box. If you where in Perth I'd happily do it for you but it's a bit of a drive at 45kmh
  6. They measure the basics and give you an estimated weight (usually +/- 8 to 10pc)EDIT- But yes you are correct the OBGYN monitors weight carefully with high risk Pregnancies as it usually one of the first indicators that something isn't right. EDIT#2 - Congrats on #2
  7. Sorry to hear that mate. I hope it goes as well for you and your family as it can.
  8. 27th of Jan mate. Little bit different to last time. Bub is already 3.5times Ralpy Jnr's Birth Wieght and 200gms heavier the He was when he came home. Gonna be a "big" little brother or sister.
  9. Wife (who's currently massively pregnant) and Jnr both sick with a Virus the Day before Xmas.
  10. I work at a site that had late 60s evaps, when they got cranked up after winter they smelt like stale tuna for a month. That's not good Yeah?
  11. Ba2 04 on where factory 6spd man double r Ron.
  12. Pats relearn will fix the security issues. Then the car will need to be tuned correctly.
  13. Do I pry my steering wheel badge off before or after I tune it?
  14. Dude, your flashing an auto tune into a manual PCM. Back to basics. Get ford to do a PATS relearn. (forscan is apparently able to do this but I haven't trued) The get an appropriate custom tune to suit the mods and the manual pcm. Or reinstall the original auto pcm and get it setup properly to suit the manual box. Pats (passive anti theft system) had the ability to reduce fuel and timing to limit the carz speed of it thinks it's been stolen, I can't say this is the case but it sounds like it.
  15. Tankful of E85 for the first time in a while f'n whooooooosh
  16. So you've fitted a manual PCM, are you still getting the "code" error on the icc and smart lock indicator? What tune is in the PCM? Did you install the manual pcm then flash your old tune back in?
  17. I can't tell you from my lounge room in Perth. Are they flashing manual tunes in or correctly setting up the ecu correctly? Shit time of to attempt it but if you're able to airbag the ecu to me I can set it up correctly. You should jump on the hp tuners forum and see if any local members to you can help you out.
  18. Would Sir like his humid day 30 deg day with excess humidity and legionaries disease or just excess humidity?
  19. Mate, just get the current pcm set up properly. I did the same conversion back in 05 no need to remove the auto loom
