Wombi90
17 Good
923 profile views
  1. And here I was googling image convertor websites signing up to 4/5 and still not getting anywhere hahaha
  2. I've been looking in how to do that since I posted lol how do I put them as img instead of jpg
  3. Bulk photos they should explain themselves. Buying a th400 and ditching the zf. Still undecided about Hotside setup yet
  4. Long time between posts this things still alive. Slowly repairing it and stockpiling parts for once it's back on the road it's getting a new roof, sill panel, 1/4, 4 doors, 2 guards, front bar and xr8 bonnet. also got new inserts for the rear bar to remove the tow bar. Heres red the run down of parts I've got for it Motor and accessories Atomic 698 short Arp 12mm headstuds Crow race valve springs and retainers Torqueline garage oil pump Crg low mount Gtx 3582 externally gated 45mm turbo smart hypergate and screamer 4" intake 4" stainless dump 4" stainless exhaust Nizpro plenum Process west stage 3 Intercooler and piping Process west battery relocation Driveline Bert kewish zf auto with Cyro'd input shaft Gibson tail shaft Eaton trutrack Fuel system Walbro 460 intank pump Plazmaman surge tank with pierburg 350lph pump 1000cc injectors Suspension, brakes and Wheels Front Brembo 4 piston callipers with 355mm discs Rear Pbr single piston with 328 ventilated discs Front Whiteline 30mm adjustable sway bar Rear Whiteline 22mm sway bar Performance suspension rear upper camber arms Kmac front camber kit Varrstoen front 19x8.5 rear 19x10.5 Extras Braided hoses in engine bay Alloy coolant reservoir Nizpro rocker cover garnish Billet oil cap Alloy ECU cover Catch can Engine oil cooler 3 gauge pod with cobalt boost and engine oil pressure Items needed Twin bush diff hat Fuel regulator Fuel rail Pwr zf cooler Shockworks coil overs 3rd gauge for pod Sunroof
  5. If someone has 5k haha Sent from my iPhone using Tapatalk
  6. I'm ok [emoji16] Sent from my iPhone using Tapatalk
  7. Lol looks like 300+
  8. $400 for gears or $3500 for a new motor you do the maths
  9. Which one Ralph?
  10. Some more parts showed up cooler and cold side piping I bought a new fpv steering wheel as mine was worn abit Old New
  11. Yeah I think I'll build a motor for this just purchased the first piece haha So will slowly keep getting items for a build. Anyone got any Piston recommendations?
  12. I'm thinking of pulling the original driveline out and storing it and just using another motor and box. Then it doesn't matter if it breaks. The more I think the more likely this is to happen and I'm keeping modifying of the body to minimal. I don't want to wreck a rare car but I do want to mod it carefully
  13. Haha this one won't be the build the other one will
  14. The gtx is already paid for and in transit so I'll probably use it. Heard they make a sweet spool noise. Some parts started to show up today. Cooler should be here tomorrow and gtx next week. Ordering valve springs fuel pump and oil pump this week. Then just injectors following week. Hopefully it's registered in vic by then an I can start the pull down
