connorebrown
  1. ticking noise in engine bay sounds like belts is this normal? Car is awsome apart from that should I get the rear diff bushes checked?
  2. Im about to buy a fg 2008 turbo private sell with 45k on the clock its had some work done making 430hp atw, should I be worried about buying it? is it going to cost me more in the long run......???
  3. I thourght there was amny places to go towards the south any other places?
  4. Hey guys just wondering where a good place to go to get a tune and upgrades in the south of perth region as far as fremantle? Cheers
  5. yeh she was def released after 06/06. bit hesitant on the buy should I go for it?
  6. with a new intercooler kit and tune would she be an alright car? should I go for the buy?
  7. He had everything done at house of power plenty of mods which include: - o ring compressor - exaust outlet gasket - oil drain gasket - lockplate turbine end - gasket small base - strip and clean turbo - machine turbo housing - coolant tank supply - turbo studs - nut turbocharger - turbo oil supply line - ngk spark plugs - 4inch turbo dump pipe - hi flo 3 1/2 race cat - bolt and gasket kit - siesmens 60lb injectors 14mm high imp - walbro gss341 fuel pump 550hp - intake fuel filter - custom tune that's the mod list he sent me. and all the dyno sheets defiantley say 433hp max at just under 18psi car still has very low ks aprox 75 000, he want around 18k for it..... very hesitant now please help.........
  8. I havnt braught the car yet but the guy im looking to buy it off has had a dyno and he has the sheets to prove as well, hes had plenty of mods. only stock 17ich aloys atm when he took me for a test drive they didnt seem to hold very much traction at all..... what do you mean about loading up 5th and 6th? and is loading 18psi to much for the car?
  9. Hey guys Just a few questions you propabley know the answers to.... 1. What are the best tyres to use with a xr6 turbo manual with aprox 430hp 18psi safe tune? 2. Are the Bf mkii gearboxes and clutches strong enough to handle that much power withou fault? 3. And whats the best intercooler kits to look at for this model and year?
