fadi75
  1. 5 months? trashed cd's? never ever happened in ASL history, trashing cd's as well. how about you pm your vin number and I can do some research? Fadi
  2. hi please contact us 0397991444 just by removing the cd's dosen't mean your cd player will start working again. u will need a replacement cd radio module. cheers fadi75
  3. What you wish to do will not work, regardless of if it can be set to NTSC. The ICC requires RGB which is similar but different from component. The converter normally converts the video out to RGB. The way it is done on the fordmods site is correct though as they are reducing the sync signal to the correct output for the screen using a specific software program. Cheers Fadi75
  4. If you interested in upgrading your base model Icc unit into a premium sound, well it could be done. From a single cd to a six indash, low screen to TFT colored screen, different color fascia's,DVD system easy install, bluetooth, DVD kits, reverse camera kits, Navigation, Carputer Products etc... all for the BA-BF/Territory well no need to look further... you have a problem-we have a solution so please let me know if u have any query.... we are an authorised Ford repair centre. For more information check out our sponsors section... ASL Sponsors Forum
  5. hi matri fadi here from asllogistics, try to fit under the front passenger seat facing forward, u should have enogh space, run the cables thru the centre console. cheers fadi75 <{POST_SNAPBACK}> thanks heaps, how should I secure it <{POST_SNAPBACK}> call me on satuday whilst u installing, will try and help. I believe u have my number cheers fadi75
  6. I'd be interested in a group buy. Any one else interested? With the additional inputs into the converter, it looks like I could still use the STB. <{POST_SNAPBACK}> Yes I will get one very soon like next week <{POST_SNAPBACK}> go to www.asllogistics.com full kit easy install @$570.00 all inc. includes dvd, rgb box, all looms and connectors, suppressors. plug in and play cheers fadi
  7. hi matri fadi here from asllogistics, try to fit under the front passenger seat facing forward, u should have enogh space, run the cables thru the centre console. cheers fadi75
  8. Its mainly only if you have a sixindash, cause if you turn upside down the cd mechanism might drop. never seen it happening. we pull them apart every day not a major concern Fadi.75
  9. Why dont you upgrade to a premium sound, will make a big difference in the sound quality.....then use high to low convertors to install an amp.....it can actually be done. from single cd to 6indash cd player...also u can upgrade from a low screen to a TFT colored screen without cutting or butchering your ICC unit,where u can connect dvd,sat nav, etc.... Cheers
  10. cool bananas!!!
  11. Mick All depends on the prices they offered you, premium sound with tft is the way. TFT can run a DVD. SAT nav Reverse cameras etc... Fadi 75
  12. I've seen a HO BA with this bulge/shaker bonnet. Didnt look that flash actually in the flesh. Those wheels though, I know where I have seen them.Mmmmmm <{POST_SNAPBACK}> Where I can get those wheels from? can anyone help!!! what they called and specs please!!!! are they BBS? ineed the exact name please, I need to get them...... can u please email me directly fadi@asllogistics.com Thanks Fadi75
