Besty221
2 Neutral
About Besty221
  • Birthday 11/12/1990
    Cobar
  • Interests
    Feeding me car
  1. Happy Birthday Besty221!
  2. Happy Birthday Besty221!
  3. Happy Birthday Besty221!
  4. Was it rapid systems?
  5. Did you do a boost leak test on your intake pipes.. What other mods u got ? U might be restricted somewhere ?
  6. How much did those valve springs cost ? Nd how much did it cost to fit ?
  7. What's your ideas on value springs ? Needed ASAP or wha ??
  8. Haha yeah mate I bought dimpled rotors nd some sticky brake pads nd wacked them on but yeah I'll eventually get brembos I guess - when I can afford them :/ do use know of any other decent set ups that are on the cheap side but are just as good ?
  9. Yeah well I guess 400kw in a manual is sorta where I wanna hang around ,, aww like ya said I'll be limita bashing everywhere haha So can you elaborate on the oil pump gears, what do they do ? , nd what do u reckon bigger/stronger tail shaft?
  10. The value springs in the bf mkII are pretty solid for 400kw how many kms on it ?
  11. What I've done so far: -Stage 3 process west front mount incooler -Process west intake plenum -4inch intake -Battery relocation -GT 3582R high flowed nd flapper mod with 64mm compressor wheel -12 psi actuator -Xforce stainless 4inch dump to 3.5 inch exhaust -earls Braided oil feed line nd high flow coolant lines -660cc injectors Looking to have done before tune: -Ace clutch option 5 -process west surge tank with single walbro 460 pump What other mods should be done before the tune to be sorta on the safe side ? How much power ruffly do you reckon I'll make pretty keen to crack 400kw mark .. Any advice would be appreciated
  12. Get a bigger turbo or get it high flowed nd bigger compressor wheel , Obviously u got a bigger waste gate actuator ? You should run in about 18psi with a set up like that
  13. So the clutch malwood supplies; ace clutches are the go I've found opt 5 was pretty successful, with bulk launches under my belt she's held up nice.. Cheers fullas
  14. Did the pump hold up alright ?? .. Pretty much got the same mods but I had my turbo high flowed with flapper mod nd 76mm compressor wheel put on .. How much power u make ??
  15. You fullas should invest in a car bra there pretty handy when traveling
