Headsex
    3
Everything posted by Headsex
  1. that's correct If you have a bunch of tunes already in your box, then you can chop and change as you wish You cannot get new tunes uploaded to your box (no more custom tune) You cannot get the box unvin locked to move it to another car (as you cannot upload new tunes to it again...)
  2. HPTuners is not the only other solution..
  3. HPTuners is not the only solutions.. And the capa flas box once already been on your vehicle is no good to anyone else..
  4. that's right.. I can confirm they removed the "Flash Xcal1 and Xcal2" menu items... The smartest thing to do right now is NOT UPDATE the software until you run out of flash counters!
  5. This will indeed, push customers to start using other products like, HPTuners and Sniper for instance..
  6. The software has a online update built into it. You have to keep updated or else you run out of "flash burns" which decrement everytime you upload a tune to a box.. So technically if you avoid updating your ADvantage 3 software, you will run out of flash counters, and be forced to do a update if you want to reset your flash counter to flash more boxes..
  7. bastard merging my thread!
  8. Well, After having a few phone calls and SMS's this morning, I have done some research and have found that SCT have locked out the use of XCAL1 flash boxes, and soon XCAL2 flash boxes. What this means is, If you want to do more custom tuning on your car with your xcal1 or xcal2 flashbox, you will need to buy a XCAL3. From what I understand, CAPA had introduced a "Unlocking service" of flash boxes, essentually unlocking a flashbox once it had programmed a car, recycling this box for use on another car. Which means, Less revenue for SCT as they were no longer selling as many boxes. Seems SCT got smart and fixed the problem by locking out use of all XCAL1 and soon XCAL2 flash devices. Dont you love the politics that continually emerge from this industry? danny.
  9. Nah, that was Cole Trickles ring tone...
  10. It was Ivans CD... dont look at me.....
  11. IF HE ONLY NEW MAX!
  12. Only a few MM? Dude.. its still about a inch too long =) When you placed it back in your tank, How hard did you have to push it down to get the screws in??
  13. was it cut the same length as the old hose? Also, I cant stand joined power wires. I sourced the same crimp fitings which fit into the ford connector, which you crimp onto the Walbro power and push the crimps into the existing ford plug... Rather than cutting and joining them (by soldering, or those walbro provided crimps!)
  14. the old and new hose is too long... it will split again regardless of what hose you use, submergable or not.. Interestingly, the host that comes in the walbro kits that I use are not rated at as SAE R310 (submergable).. But I dont know of ANY car ive fitted this kit to ever have any problems, and need to change the pipe... Envy, Have you got a new pump yet? I'll show you how it needs to be fitted =)
  15. 8f's ramp rate is too loose to load up the turbo to its full boost potential. 6f is better, but still a "little" loose incomparison with the road
  16. I dont think need to say error int his one... it speaks for itself
  17. So I was lookat at youtube for same new dance moves... ERRROR
  18. my car has 300rwkw
  19. Yours had STD intake plumbing but different cooler. It seemed quite good, no sign of overboost. But if u had underbattery pipe or different cooler plumbing there may have been a problem
  20. Troughy has had a fair few tunes in his car.. Both the tune I put in his car, and the other tune, were between the 295 to 305rwkw mark, so both tunes made the same power, However the curves on them were very much different. Troughy had ran both tunes back to back down his local drag strip, and well you can guess whos tune was quicker.. Troughy can give the exact details on how much quicker..
  21. 15psi boost, 98 fuel. It had overboosting problems previously, so I ported the wastegate, and gave it a famous headsextune. Mind you, this car was only street tuned.. I did not dyno prior, AFRs were spot on, and boost was stable. Even Darren from carby better was a little surprised... look at this face
  22. Love the Jetski dico.... I guess you guys must have been bored up at barmaaaaaaaaaaaahhhhhhhhh
  23. Hahah yeah.. a mate of mine in Florida found it and said it was a bit close to home for me wasnt it?? http://www.abc.net.au/news/stories/2009/01/13/2465001.htm
  24. THIS IS ROCK AND ROLL ERROR
