ranuip
710 profile views
  1. Anybody done the cams and tune on an na fg xr6?. Thinking about doing it, just want the nice burble it makes..... Sent from my C6603 using Tapatalk
  2. What does it do then if you just run a straight pipe to the throttle body??
  3. The two bulges out either side of the intake pipe before the throttle body?
  4. Edit that "all rides on here"
  5. Kffl-40SSL front Kffl-68SSSL rear With sach shocks to match....with stock 17s 2010 XR6. Rides well and corners a heap better, bit of camber on the front and I cut the bump stops. Will post a pic when I can. Some rides on here...awesome.
  6. That looks boss!
  7. Mine just did the same thing today, but only the passenger side. Pulled out and put fuse back in, now all good.
  8. What's the difference between the F6 and the XR6 air box and snorkel? Is it worth buying to replace the standard AIRBOX on an XR6?
  9. So the caps farkd....? Or the engine?? Getting a replacement tank and cap on the weekend. Hopefully that's all it is and not something worse
  10. My FG XR6 just did this. Not driving it hard at all, parked and turned the engine off and it started spewing coolant....... Looks like it came the ought the top cap!? What's up with that!!!??? Just when u get on top of things something else always comes up!!
  11. Hi all, I put my car in for its 75000km service and asked the mech to put some of these NGK iridium plugs in (got them free) because I thought they would be all good. He told me that the don't make any difference and that the standard ford plugs they use are better and last longer anyway (150000km)........... Any thoughts?!?
  12. Done my fronts. Too easy, the trims are easy to get off and doubled up the spacers for the 6 1/2's. just put some Sony xplode 2 ways..... They sound heaps better. Do the rears next week. Just put some 6 1/2's in there as well....... Not sure which ones though, something with a bit of bass.... Any ideas??
  13. Would be keen to know if anyone's done this too......
