YOB POM
About YOB POM
  • Birthday 16/06/1956
    Jimboomba Qld
  1. Happy Birthday YOB POM!
  2. Happy Birthday YOB POM!
  3. Happy Birthday YOB POM!
  4. Happy Birthday YOB POM!
  5. YOB POM
    Charlie Sheen
    Hypno Doc My comments were more at Gibson than Sheen although I think sheen is a dickhead he he's only harming himself. As for Gibson he is a a anti semetic, holocaust denying, fundamentalist Catholic *beep*. As for the media, well I get my info from many sources and yes there is a lot of bullsh*t but to simply write off any thing in the media is ridiculous.As for thinking that 90% of people in the street are arse holes do you include 90% of this forum? John.
  6. YOB POM
    Charlie Sheen
    Hypno Doc. Your right he's just like Mel Gibson,a complete arse wipe. John.
  7. If you only went cat back you wont need a tune. If you want a V8 rumble you need a flat plane crank and discreet exhaust manifolds with the right firing order. John.
  8. To test the mounts put your foot on the brake in drive and give the engine a few revs.If the engine rocks to one side your mounts are stuffed,as for the vibration all I can suggest is get the vehicle on a hoist or similar and just poke around with the engine running to isolate the noise,usually the exhaust heat shield.
  9. Engine mount causing the vibration and the exhaust heat shield the noise? John
  10. Their glass polish is second to non. John.
  11. Took me less 1 hour. John.
  12. YOB POM
    Dba Rotors
    Unless you love cleaning your wheels on a daily basis I would stay away from Bendix Ultimates. I switched to Bendix Stealth last pad change and couldn't be happier,no dust, silent and work well when cold. John.
  13. YOB POM
    Dba Rotors
    Lots of guys use them and are very happy. Will be doing the same next pad change. http://www.superoneauto.com.au/shops/ford-bits/products/ford-ba-bf/brakes John.
  14. It's been shown that although blue light looks brighter they actually reduce vision. John.
  15. Does the pcv valve rattle? If it does it should be ok. Cheap enough to replace any way, however that amount of crankcase pressure sounds like a more serious problem.Do a compression test as it sounds like it could be blowby pass your rings,it doesn't take much wear with forced induction. John.
