MJS
5 Neutral
About MJS
  • Birthday 23/05/1976
    GYMEA
  • Interests
    Cars and Cricket!
826 profile views
  1. CJF077
    Happy Birthday MJS!
  2. MJS
    454.2 Rwkw
    Hopefully wed 9th July, the gearbox should have worn in by then. Will post WSID results, however it drives like a tight car even with lower ''Dyno figures''. It drives linear and shifts hard but forward, if that makes sense. Not all or nothing! MJS Cheers Joe@CMS
  3. MJS
    454.2 Rwkw
    If anyone reads this update, life and babies have interrupted things, car has since blown the ZF box. Stacked with clutches and replaced twisted input shaft. Gearbox and engine retuned by Joe@CMS Motors. His dyno reports 370rwkw with a little wheel spin. Cant wait to pick up. No disrespect to other tuners but these figures seem to be more realistic. (read full post). Will report track times @ WSID.
  4. CJF077
    Happy Birthday MJS!
  5. MJS
    454.2 Rwkw
    Is there a race day on sunday? I'm working anyhoo!
  6. MJS
    454.2 Rwkw
    Usual codes are abuse, traction and idle(has been stalling since the gain in power, 370 to 454rwkw) . My tuner has sorted them out but something new always pops up! Im going to try something on my first run, which funny enough was an accident when it was my mates car with 370rwkw. I put in Perf mode in 2nd to do the burnout but forgot to tap down to first, so car takes of fairly slow considering what I knew it had. So I'm sweating on the 1-2 gear change that doesn't come til 3/4 track into 3rd and passed trap 12.4@116. The engine light came on and since it wasn't my car that was it, one pass. So with more power/torque Ill try it again 2nd in Perf and lean on it hard 2000ish.
  7. MJS
    454.2 Rwkw
    I'm changing that luck tomorrow!! WSID for any Sydney members, weather permitting, looks good though. I know I've had a good night when I drive home with the engine light on! Its on so much I'm worried when its off.....
  8. MJS
    454.2 Rwkw
    Yeah I know, I'm pretty sure you have been following this post and a bit has been said about my crappy time vs power claim. First run- I did a big burnout, car put transmission in limp mode, 17 sec. Trac off. Second run- I did small burnout, Mashed the pedal and car went berko at 1st to 2nd gear change bent all out off shape seriously. 13.8@116 Trac off. Third run- I figure Trac on and see if it improves, it does 12.6@118.26. Tyres Hankook Ventis Rs-3 semi slicks, still no Yoko Advan Neoveo(I had on previous ride WRX). I know racing with Traction on is pointless but it made sense at the time considering I wanted to go home, with a decent time in my daily driver that I have spent plenty coin on!
  9. MJS
    454.2 Rwkw
    It is 454rwkw/608rwhp, happy dynos aside, I'm as sh11ty about time/trap speed as members are skeptable. The best run is 12.6@118.23, anyone with 350-450+ think about how much time I was losing every time the traction pulled me up. even .1 second each time say 10 times in 400m makes 11.6@??? Im going to WSID on Wed weather permitting and seeing my tuner before then so hopefully I have better news.
  10. MJS
    454.2 Rwkw
    I,am familiar with happy dyno's, the conditions were perfect(cold&dry). I can only give stats on engine mods, that have been given to me, like I mentioned PW fuel regulator and W460 2.4L Surge tank(does that help)? I had putrid traction at WSID, therefore the figures. Best run 12.6@118.23 with traction ON!!. Slow out the box and traction control holding me back. I'm looking on the net for 275/40/17 MT E/T Radials, Seems hard , my have to buy them new, then post some real times!
  11. MJS
    454.2 Rwkw
    I don't know what dyno it is but it is a AWD dyno if that helps. In regards the injectors we reached 440rwkw with 42lb and Walboro 500hp, when ran out of fuel to motor. Put in 60lb made 454.2 at 19psi. Does the fact I also put in PW fuel regulator and W460 2.4L surge tank help explain anything. These days I'm a pay a professional as opposed to 20yrs ago when I stood in the engine bay of my LC Torana and tinkered!!
  12. Anyone going to WSID this arvo. I get there early so I'll catch the second half of N.S.W WIN!!!
  13. MJS
    454.2 Rwkw
    Yeah I don't know where 470 came from its 454rwkw.
  14. MJS
    454.2 Rwkw
    Mirrored for artistic effect.
  15. MJS
    454.2 Rwkw
    This is Rubbish, but Ill learn!
