sam71093
12 Good
About sam71093
  • Birthday 07/10/1993
  • Interests
    Cars
    Motocross
1,323 profile views
  1. ahhh sweet fortunately I happen to have a second set of calipers from my other falcon from when I switched to brembos ill put them on and see how it is thanks.
  2. Front left caliper is dragging causing brake to get extremely hot could only just turn wheel by hand is this a sign of a faulty brake booster. Pad wear is even, slides on caliper were moving smoothly. any help would be appreciated.
  3. Happy Birthday sam71093!
  4. Just installed NPC copper mix single plate in my FG turbo seems great so far
  5. Hi all, I just installed a new clutch kit and a remote bleed line from NPC. The remote bleed line came with a bleed nipple that works like check valve and seals on a taper. As I believe you should just crack it then pump the pedal and it should bleed and not let any air back into the system. My issue is, when I just crack it nothing happens, so I undo it a little more then it fluid bleeds through the treads so I tried thread tape but nothing seems to work. It seems that I may have the wrong one as it only screws in like 3 threads (doesn't even make it to the black thread sealant it has on there as seen in photo) then it seals up on the taper. Any info would be great if all else fails can I just buy a normal bleed nipple and use a vacuum bleeder. Thanks In Advance
  6. Cheers for the info these will defiantly be my next purchase
  7. When you say lower it extra over the weekend it is as easy as just using a C spanner and putting more preload on the spring
  8. Thanks for that ill head over there for a look
  9. Hi All, Been reading up about coilovers seen a few people rating the shockworks ones. I am not after super low I just want car to sit level and a improvement in handling. Any comments/feedback about them would be appreciated to help me make up my mind
  10. I fitted all the parts myself except injectors & Flapper Mod so all up it was around 6K
  11. Thanks yeah boost was 16psi tapering off to 12psi
  12. Picked my car up from Joe@CMS today and made the 300+ club, wow what a great transformation absolutely love the new found power, Joe was really helpful and didn't mind answering any questions I had. I would highly recommend him. - Process West Stepped Intercooler + Piping - Process West Turbo Side Airbox - Plazmaman Battery Relocation - Xforce Turbo Back Exhaust - 12PSI wastegate actuator + Flapper mod - KPM 1000cc Injectors - Earls turbo line filter kit Made 326RWKW so I was more than happy
  13. Happy Birthday sam71093!
  14. Yep your right I was just thinking the worst
  15. Hi I had my car up on the hoist today having a bit of an inspection and noticed oil leaking from in-between the block and the head (see attached photo) just wondering should this be a concern as car only has 23,000km and is a 2012 model also would it be warrantable through ford
